Insulating A 1885 Crawlspace - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 11:26 AM   #1
insulating a 1885 crawlspace
our 1800s farmhouse is built on a foundation of stones with a 24" crawlspace - the floor is freezing and I'm concerned about black mold - is insulation under the house practical?
rowilli56 is offline   Reply With Quote
Old 01-31-2011, 11:41 AM   #2
Rewards Points: 282
Absolutely, why not? Is it a vented crawlspace or non-vented crawlspace? Do some searches on youtube. They do a good job of showing you exactly what to do, and give suggestions and ideas. There is a vapor barrier that should go down on the dirt-floor to prevent moisture whisking up to the floor causing water/mold issues. If it's non-vented you can insulate the walls of the crawlspace foundation. Insulate between the floor joists as well. It all helps....
cbaur88 is offline   Reply With Quote
The Following User Says Thank You to cbaur88 For This Useful Post:
rowilli56 (01-31-2011)
Old 01-31-2011, 12:46 PM   #3
Rewards Points: 120
You can do searches on this site as well, as there have been a good number of threads related to crawlspace insulation. Without actually seeing it, it's hard to say for sure, but given the type of foundation and the age of the house, it is very likely that you could make a measurable dent in it with simple caulking, spray foam insulation, and rigid insulation, at the perimeter of the joists. In fact, it is very likely that if you were to go down there during the day, and have someone turn the lights off for a minute or two, you may very well see numerous points where your heating costs are escaping you.
properly insulating a crawlspace mcvane Building & Construction 5 02-01-2010 08:56 PM
Crawlspace Moisture - Serious Problem PaoloM General DIY Discussions 11 12-15-2009 01:35 PM
Insulating an unheated crawlspace indignatz Building & Construction 7 10-28-2009 06:29 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
Insulating duct run in vented crawlspace Magus HVAC 2 11-29-2006 03:09 PM
