Insulatign Cathedral Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2010, 04:02 PM   #1
Hey everyone. I am in the process of redoing my bath upstairs in my 1950s built, story and a half home. I have some walls off and noticed that the insulation they currently have is not sufficient. I am looking to make the entire upper level into an open cathedral/vaulted type ceiling and have been reading what ever I can find on insulation.
I am looking for ideas as to how I can insulate the ceiling under b, which will be the underside of the roof, in the rafters where they have 2x6s. d is the ceiling piece that I am looking to remove entirely. The problem that I keep running into is that I want to close up the two vents, letter a, on the sides of my home to fully inclose the upstairs. Also, what kind of ventilation is needed for section b, e and within the crawl spaces?
Any ideas are welcome.
Please reference the attached pdf for the labeled diagram.
Dutchman80 is offline   Reply With Quote
Old 01-07-2010, 04:08 PM   #2
What is the current height of the ceiling - wall "C"
Where are you located ?
Old 01-07-2010, 04:22 PM   #3
About 7.5 feet, give or take 3 inches
Old 01-07-2010, 04:22 PM   #4
Minnesota, suburb of Minneapolis
Old 01-07-2010, 04:33 PM   #5
Multiple possible issues
Main problem is that the boards going across at "D" to make the ceiling might be required as part of the roof
Do you know the span - the distance from the middle of the room all the way out to the outside wall
With 2x6's you will need to furr these out in order to install R38 insulation
Is this entire area already living space?
You would need a ridge vent to replace the gable vents
Rafter vents are then placed in each rafter bay for ventilation
You need 12" of space for the rafter vents & insulation
So you need to add another 2x6 to the existing 2x6's to make them depthwise equiv to a 2x12
Old 01-07-2010, 10:17 PM   #6
Registered User
Rewards Points: 5,482
Ridge board and collar ties is what you have. You need a ridge beam (engineered) to get what you want: http://books.google.com/books?id=E5S...20beam&f=false
Be safe, Gary
Condensation on cathedral ceiling barbaraizac Roofing/Siding 46 09-26-2009 10:48 PM
inulation above cathedral ceiling LanterDan Building & Construction 14 06-11-2008 02:57 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
Cathedral ceiling ventilation dpreznik Roofing/Siding 2 10-31-2006 10:18 AM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 11:19 AM
