Insulated Walls For Outside Hot Tub? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-15-2010, 04:55 PM   #1
insulated walls for outside hot tub?
hi all,
I am trying to install a hot tub outside on the deck; the deck is on-the-ground with pilings and correct framing to hold the load. The deck is structurally sound and was built to hold a hot tub.
My issue is insulating the short 2 foot walls that hold the tub, as well as possibly underneath the tub but on top of the deck, like a platform.
Exactly, how to insulate the tub with what materials/methods etc... What size of walls, if any, to build all on top of the existing un-insulated deck
Does anyone have any input on this topic?
thanks
wwsteel is offline   Reply With Quote
Old 10-15-2010, 08:33 PM   #2
remodeling pro
I would not try to insulate the deck or tub surround walls at all. This is just creating a moisture trap that will lead to mold and eventually rot the wood. The outside of the tub should be sprayed with urethane insulation from the manufacturer, and as long as the tub is kept covered when not in use, it will maintain it's temperature with minimal energy usage.
troubleseeker is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Basement half walls to full walls Basement Man Remodeling 11 03-29-2009 02:33 PM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 03:07 PM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 03:10 PM
Moisture on walls chrisr Building & Construction 1 01-20-2008 09:37 AM
