Insulated Vinyl Siding And Thick J-channel - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 11:39 AM   #1
Rewards Points: 83
Insulated vinyl siding and thick J-channel
Hello,
I'm in the process of replacing windows and siding on my house, and I'm looking for suggestions on how to make the window casing look good with a thick J-channel.
The windows were replaced with Andersen 400's, which have frames that extend about 1.25" out from the flange. I am going to have insulated siding installed (CertainTeed Cedarboard or Alside Prodigy), and with the integrated insulation these typically need a thick J-channel (I believe 1.25"). I want want to install traditional casings around the windows made with 1 x 4" Azek (or possible 5/4 x 4"), but I'm concerned about the depth profile. Regardless of which trim board thickness I use, the J-channel will be proud of the casing and I'm afraid it will look bad.
Has anyone installed one of these insulated siding products and dealt with this?
Also, if I wanted to build up the casings a bit, can I cut 3.5" strips of 3/8" or 1/2" rigid foam board and sandwich these under the Azek? You wouldn't see it, since the J-channel would butt up against the outer edge of the Azek/foab board.
Thank you.
cumak is offline   Reply With Quote
Old 08-31-2010, 11:43 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
yes you can pack out using foam,just make sure you put a drip cap at the head under the j
Tom Struble is offline   Reply With Quote
Old 08-31-2010, 07:32 PM   #3
Rewards Points: 83
Thanks. And, any thoughts on how to handle the thickness of the J-channel? Should I just build out the casing so that it is about flush?
Old 08-31-2010, 08:10 PM   #4
yes,if you like that betteri like the trim proud of the andersen,so there ya go
vinyl siding over asbestos?? Buckeyes97 Remodeling 12 08-21-2012 09:20 PM
Covering large hole in vinyl siding eastie Building & Construction 4 04-01-2010 08:43 AM
Shopping for vinyl siding???? justdon Building & Construction 5 09-01-2007 06:14 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
