Insulated Vinyl Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-14-2011, 08:11 AM   #1
Rewards Points: 640
insulated vinyl siding
well the vinyl siding on my house right now is the thin contractor cheap stuff... and when it was built they didn't even overlap pieces more then 1/8 of an inch, so when the house expans and contracts gaps start to show.... so starting to think about residing it...
I want to go with the insulated siding, not just because its insulated, but since it will help dampen noise penetration, and make the siding more rigid.
but what is out there in terms of choices? I saw "drop in" and "laminated" what's the difference? does one have the insulation attached to it and the other just have insulation pieces you put in?
whats the cost difference between it and hollow siding?
any ideas on who the best company is making it right now?
BlueBSH is offline   Reply With Quote
Insulated vinyl siding and thick J-channel cumak Building & Construction 3 08-31-2010 08:10 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
