Insulated Or Non-Insulated Vinyl Siding? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-31-2011, 02:56 PM   #16
Tom Struble's Avatar
Rewards Points: 2,002
the insulation thats attached to the siding is ''not just tacked'' as you say,it is firmly held in place between the panel lock
and the installation detail is all the foam is butted,there are no big gaps between the foam
and Gary please when you reply to me don't give me all those links,it's kind of annoying
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
AGWhitehouse (07-31-2011)
Old 07-31-2011, 03:48 PM   #17
Registered User
Rewards Points: 5,516
Sorry about that. No more links for you. Ventilating air pockets, water channels, fire-retardant and bug resistant insulation, now if it was fire retardant and non-fading vinyl that still looks good after 10 years, it would be a quality product. (My opinion). With no air movement and an insulating air film, one would still need a foam board for the required exterior insulation to make-up the low R-value of vinyl in most of the U.S. and Canada, if interested in dew points.
OP, have you decided which way to go yet?
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Tom Struble (07-31-2011)
Old 07-31-2011, 05:46 PM   #18
thankyou
i'm not trying to be an advocate for insulated vinyl siding,but installed right it will do as advertized
Tags
insulated vinyl siding , vinyl siding
insulated vinyl siding BlueBSH Building & Construction 0 04-14-2011 08:11 AM
Insulated vinyl siding and thick J-channel cumak Building & Construction 3 08-31-2010 08:10 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
