Insulated Or Non-Insulated Vinyl Siding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 09:41 PM   #1
Insulated or Non-Insulated Vinyl Siding?
My home was built in the 80"s, I have brick on the first floor, and I am planning to installing siding on the second floor. Does anyone know if it is wiser to install a premium vinyl siding that comes with the insulation, or install a premium non-insulated vinyl siding combined with a higher R-value rigid foam insulation? Most of the insulated vinyl sidings I've seen have R-values of 5 or less. I realize I can achieve two to three time that R-value with the rigid foam insulation, but I'm not sure which option is the more expensive or efficient.
I would appreciate any feed back you my offer.
Cheers
dv817 is offline   Reply With Quote
Old 07-18-2011, 01:00 AM   #2
Rewards Points: 1,092
I'm not a pro, but how the hey is insulation in siding worth jack stink when siding is not air tight? insulated siding makes as much sense as breasts on a bull, unless i'm missing something (besides a few screws). btw, if you put foam on the outside, make sure you have enough to keep the sheathing underneath it warm (to avoid condensation). generally, that means 2" of foam over 2x4s, 3" over 2x6s.
Old 07-18-2011, 09:03 AM   #3
The main advantage of the foam on the back of the panels is that it makes them nice and firm with no play like there is in regular vinyl. The for the insulation value of it is negligible. One disadvantage is it does not pop off easy with a zip tool if you need to do anything behind it or replace a piece
parts is offline   Reply With Quote
Old 07-18-2011, 11:25 AM   #4
AGWhitehouse's Avatar
I wouldn't recommend the insulated siding because of air movement like jklingel said.
If you are going to put rigid insulation on the exterior envelope you will need to pay attention to it's vapor permeability. Most structure were built with a vapor barrier on the interior side. If you put enough foam on the exterior side that a vapor barrier (< 1 perm) is made you will trap moisture within the wall and create an opportunity for mold growth.
AGWhitehouse is offline   Reply With Quote
Old 07-18-2011, 11:54 AM   #5
Installing Radiant Barriers under Vinyl Siding
If one installs foil radiant barrier under non-insulated vinyl siding, obviously it will reduce radiant heat, but will it cause a vapor barrier that could trap moisture in the walls and create an opportunity for mold growth?
Old 07-18-2011, 12:03 PM   #6
If the barrier has a low perm rating then yes. <1 perms is considered a vapor barrier by the IBC. If the foil faced barrier is permeable (i.e. has perforations), then it will reflect the heat and allow for vapor transmissions.
Old 07-18-2011, 01:13 PM   #7
AGWhitehouse,
I had a feeling that would be the case. I just did some research online after reading your valuable comments, and I did not previously know that foil radiant barrier comes in perforated and non-perforated. Additionally, I also learned that the minimum rating for a perforated product should be 5 perms.
Thanks for you help!
Old 07-21-2011, 10:23 PM   #8
Registered User
Rewards Points: 5,514
Check to see if the foam is EPS, as it probably is (which you don’t want). Do your homework….. http://docs.google.com/viewer?a=v&q=...t5jlOsa_kZRRgw
Radiant barrier requirements, and “double vapor barriers” with XPS; http://docs.google.com/viewer?a=v&q=...4EyM707m0gPdXQ
Gary
Old 07-24-2011, 08:28 PM   #9
Registered User
And the one I was thinking of but couldn't find until now: http://hubpages.com/hub/Does-Foam-Bo...lp-Save-Energy
Gary
Old 07-24-2011, 08:57 PM   #10
Why no on EPS? It is a very breathable foam product that is great for adding some R-value without creating a double vapor retarder system. XPS is a wonderful product, but can only be applied in a thin layer for retrofit due to its lower permeability rating and chance of creating a double retarder.
Life's too short...so enjoy it!
Old 07-28-2011, 10:23 PM   #11
Registered User
Read the links on post #8..........
Gary
Old 07-29-2011, 10:07 AM   #12
Gary
Ok...that was a pros/cons comparison of EPS backed vinyl siding and XPS sheathing. What of EPS sheathing vs. XPS sheathing? That's my question...
Old 07-30-2011, 11:17 AM   #13
Registered User
ESP has it's place if you don't mind less R-value for the thickness, or adding a housewrap. Long as you never have a water leak from siding, windows or roof. From page 14: “However, the EPS wall appears to have stable moisture
cycling behavior, and is even drier than the original wall
during the wintertime peaks. Although these simulations
might point to EPS as a promising option for exterior insulation
retrofits, there are some drawbacks to this material,
including lower R-value per inch, lower compressive strength,
poorer workability (edge cutting), and difficulty in detailing
the material as a water control layer/drainage plane.”
http://www.buildingscience.com/docum...ation-retrofit
It’s the water………. http://docs.google.com/viewer?a=v&q=...4EyM707m0gPdXQ
Gary
Old 07-30-2011, 05:45 PM   #14
Tom Struble's Avatar
Rewards Points: 2,002
eps is the correct type of foam when used on an attached vinyl panel
and you really need to understand how air ''sticks'' to a surface to understand
that even though it may not be air tight it can still be an effective way to add extra insulation to your home
Tom Struble is offline   Reply With Quote
Old 07-31-2011, 02:28 PM   #15
Registered User
“The impact of forced convection
upon thermal performance”, page 4,
mentions wind-washing “short-circuiting” insulating sheathings. With all the joints and trim connections with vinyl siding, I doubt you would get benefit of the air-space (R-1) and possibly not even the outside air film R-value of 0.17 of insulated siding, since it’s just hanging there, tacked at the top. http://www.aecb.net/PDFs/Impact_of_thermal_bypass.pdf
R-value of air-spaces, bottom of graph: http://www.coloradoenergy.org/procor...f/r-values.htm
I’d rather use a rigid sheathing with a housewrap or paper, knowing you’d get the listed R-values, staying drier as vinyl siding leaks water: http://sidingmaster.com/documents/Ne...ngmoisture.pdf
Why would you want an air space between the insulation and the sheathing to negate any R-value, possibly raising the dew-point of the wall at the inside sheathing: http://www.greenbuildingadvisor.com/...ally-necessary
The foam has to be next to the sheathing, without an air space, to be effective; http://www.greenbuildingadvisor.com/...foam-sheathing
Gary
Tags
insulated vinyl siding , vinyl siding
insulated vinyl siding BlueBSH Building & Construction 0 04-14-2011 08:11 AM
Insulated vinyl siding and thick J-channel cumak Building & Construction 3 08-31-2010 08:10 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
