Insulate Under A Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-04-2011, 08:54 PM   #1
insulate under a deck
My problem is i have a manufactured home that has a deck built onto the front corner of the home the floor is just regular deck boards. Under the home it has a perm block foundation. My issue is when it gets cold my water freezes because my water comes in under the deck and i get rain, snow, and cold air coming down thru the spaces of the deck boards. Does anyone know a way to insulate it so that it stops the air, rain, snow etc from causing my water to freeze. I have my water pipes insulated with foam tube insulation. I have thought about just putting in roll insulation up but im afraid that with the rain that comes in it will just get wet and then i will have to deal with mold and rot. Please help because all i can come up with is to run a new water line that doesnt come out under my deck.
damifino is offline   Reply With Quote
Old 01-05-2011, 05:54 AM   #2
I suspect that insulating the deck is a waste of time. Insulating the pipes better would be the thing to do. Using heat tape/wire under the pipe insualtion should help.
to insulate or not to insulate? tiffertots Building & Construction 0 10-20-2010 11:13 AM
Desk building Red Squirrel Carpentry 3 06-20-2010 06:27 PM
What is standard height for recessed light above a desk? andmmy Electrical 2 06-15-2009 06:21 PM
Desk Construction Question StrangeTim Carpentry 5 04-26-2009 11:11 AM
Old flip top school desk Zarack Carpentry 15 09-09-2008 09:57 PM
