To Insulate Or Not To Insulate? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-24-2010, 12:01 AM   #1
To insulate or not to insulate?
I'm going to redo a bathroom and kitchen in my house, which has a brick exterior. I have the bathroom gutted to the studs and I noticed there was no insulation between the old tub/surround and the brick wall. Is this common? Do I need to frame out a wall to insulate it or will I be ok?
thanks
brokenhammer is offline   Reply With Quote
Old 11-24-2010, 01:04 AM   #2
Rewards Points: 1,092
Insulate if it will save you money or help keep the tub water warmer. Use eps or xps, no fiberglass, and no vapor barrier. If you do install any sheet rock, make sure it is for humid conditions, and make sure your bathroom fan is working and the ducting is sealed. This may be a good time to install a Panasonic Whisper Green fan, if a fan is needed.
Old 11-24-2010, 06:10 AM   #3
Does it actually have studs, or was the exterior wall only framed with furring strips??? If furring strips, what was suggested above, unless you have the space needed to install a full frame for R19 or better insualtion.
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 03:41 PM
to insulate or not to insulate? tiffertots Building & Construction 0 10-20-2010 11:13 AM
How to Insulate behind Wall Stack Supply Duct whirly HVAC 5 03-08-2010 04:47 PM
do I need to frame my basement insulate with batt insulation? y2chuck Remodeling 3 02-15-2010 08:13 AM
Insulate or Don't Insulate? helpless handyman Building & Construction 10 03-31-2008 06:07 PM
