Insulate Inside Basement Closet? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 07:37 AM   #1
Question
insulate inside basement closet?
we are in the middle of a basement remodel and there is a storage closet under our stairs to the basement. the stairway is against an exterior north wall - and i don't think there is insulation behind the drywall - don't know if i'm going to tackle that one BUT the closet under the stairs obviously has the one wall to the north - and then one small wall to the east that would be our foundation, but then has bricks - and then there is a piece of thin wood paneling - no insulation.
My question is - is it worth it to pull that wood out and put in some insulation - i think it's only framed on the edges with 2x4's so i could put in styrofoam sheets - (maybe) 2 in" if that.
the ceiling of the closet - is the floor in our kitchen which is at the top of the stairs, has a sliding patio door to the north - and then firedoor to the garage. our house is about 1 ft above the garage floor.
that patch of floor has one heat vent - but the floor right there is VERY cold. I don't know if i take the ceiling panel of wood out of the closet if i'll be able to get to the rim joist - which i'm sure is not insulated just like our unfinished side of the basement - did that a while ago.
would that even help keep that part of the floor warmer? i read on a gov site about energy/heat that it's not usually beneficial to insulate the ceiling in unfinished parts so is it worth it to do it?
qchawkfan is offline   Reply With Quote
Old 01-02-2010, 10:01 PM   #2
Well if you can get at the rim joist in that area I would insulate it -- you felt it was worthwhile to insulate the rest of the rim joists in the unfinished area you said.
meboatermike is offline   Reply With Quote
Old 01-08-2010, 10:20 AM   #3
i insulated this area and have to say that our floor is much warmer - when i pulled the paneling out i found the rim joist in that area was not insulated and alot of cold air was making its way into the house this way. with a heat vent in that area - it's now insulated and the air out of the vent is nice and warm now.
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 04:41 PM
closet flange ....over the drain pipe or inside the drain pipe moegumble Plumbing 2 08-18-2009 08:09 AM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 07:38 PM
basement insulation questions CooperChloe Building & Construction 3 02-03-2009 08:54 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
