Insulate Gap B/ween Chimney And Framing Inside, Yay Or Nay? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 03:25 PM   #1
Rewards Points: 1,062
insulate gap b/ween chimney and framing inside, yay or nay?
I am debating whether to stuff this space with fiberglass insulation or not. The advantage of not doing it is because the chimney (pictured left) is usually warm, radiates heat so why not piggyback on the smoke's way out.
Thoughts?
Old 05-02-2012, 12:22 AM   #2
Registered User
Rewards Points: 526
Should be fire-blocked with tin between floors: How to fireblock framing
Make sure the pipes have a pitch for the flue gases to rise and out. Seal the smaller pipe where it joins the larger pipe with mastic (if not already done) as in the fire-block thread. Furr the narrow frame wall next to the tub for room to tile, it appears the wall is recessed behind the tub face...
Gary
Old 05-02-2012, 01:55 AM   #3
thanks ... i put a piece of drywall on the floor (right above the pipes and on top of sole plates). but the original question was really whether to thermally insulate the vertical gap between the cement board on the right and the chimney on the left of the picture.
Old 05-02-2012, 08:37 AM   #4
Rewards Points: 14,026
Not sure how your going to be able to finish out that wall on the left, in the picture it looks like you must have added some more subflooring or some pretty thick underlayment and now there's nothing left to attach the bottom of the rock to.
That whole also wall also does not come out far enough, not sure how your going to finish it off around the tub.
But I'm sure you have a plan in mind.
Old 05-02-2012, 12:57 PM   #5
it's a gap and there won't be any finishing on the wall on the left. it's an open view, there will be cement board and drywall covering the opening, which is not there now so that i could take the picture and show it.
Chimney Rattles/Sways in Windy Weather cprice12 Concrete, Stone & Masonry 10 09-28-2012 10:36 PM
Replacing a Brick Chimney GeauxCajuns82 Building & Construction 4 04-16-2009 07:20 PM
Where a wall meets a chimney joelbuckley Carpentry 12 11-13-2008 03:19 PM
framing out a wall around a chimney pjm Carpentry 12 05-09-2008 07:33 AM
