Insulate Ducts, Freezing Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-19-2012, 04:22 PM   #1
Rewards Points: 49
insulate ducts, freezing basement
Hi,
My basement is unfinished and is much colder than the upstairs, so I am wasting some energy thru the ductwork itself.
The 2-3 vents are closed, but do people insulated the ducts usually intheir basements?
If so....what is the most cost effective way? Fiberglass doesnt sound good..fibers above our heads, possible cindesing and moisture.
XPS cut and boxed around it?
Thanks!
kree is offline   Reply With Quote
Old 05-19-2012, 08:50 PM   #2
Rewards Points: 12,808
http://www.house-energy.com/Insulati...Insulation.htm
Is this a feasible way to insulate a basement floor? CarlsonRower Insulation 17 12-11-2011 08:45 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Want to insulate walls in my unfinished basement strategery Insulation 9 08-20-2011 02:35 PM
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 04:41 PM
Framing in basement attached to concrete blocks, how to insulate? drnormie Remodeling 11 01-21-2009 06:40 PM
