Insulate Or Don't Insulate? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-29-2008, 09:37 PM   #1
Insulate or Don't Insulate?
I am starting to finish my basement, I am wondering if I should insulate the ceiling? The floor above seems to get cold at times, and it's hardwood floors.
helpless handyman is offline   Reply With Quote
Old 03-30-2008, 06:34 AM   #2
Just finished mine.Warm toes on the 1st floor and she loves it.Just remember not to cover up or better yet move those important accesses.
mark942 is offline   Reply With Quote
Old 03-30-2008, 08:37 AM   #3
Hey Mark, so did you insulate the ceiling? Thanks
Old 03-30-2008, 08:41 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you have a non-insulated basement, then you should consider insulating the area of those first floor joists (basement ceiling).
- Build Well -
Old 03-30-2008, 07:39 PM   #5
Thanks Atlantic, so otherwise if I insulate the side walls, you are saying I won't have to insulate the basement ceiling? Is this correct? Thanks, what to make sure. Thanks Again Atlantic
Old 03-31-2008, 05:39 AM   #6
Insulated the entire basement.Walls/ceiling every nook and cranny.....With all that I had to also install a heat source flooring ect ect ect.
But I always over kill.A guy/gal could just insulate the rim joist area,and maybe one row out from there.I am thinking that is what Atlantic is saying...........................
Old 03-31-2008, 07:25 AM   #7
Once you insulate the basement walls, you then make that basement ceiling area, part of the thermal envelope. Thus, it is part of the conditioned environment of the home, and does not rquire insulation.
Just make sure that you insulate the basement joist bay areas above the mudsills. They are esentially, part of the walls (in terms of the thermal envelope).
- Build Well -
Old 03-31-2008, 12:37 PM   #8
Rewards Points: 150
You may want to insulate the ceiling for sound.
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 03-31-2008, 04:18 PM   #9
Rewards Points: 1,062
Question
what is a thermal envelope ?
Old 03-31-2008, 05:27 PM   #10
The Thermal Envelope
A "thermal envelope" is everything about the house that serves to shield the living space from the outdoors. It includes the wall and roof assemblies, insulation, windows, doors, finishes, weather-stripping, and air/vapor retarders... -http://www.pueblo.gsa.gov/cic_text/h...ff/energy.html
- Build Well -
Old 03-31-2008, 07:07 PM   #11
I am framing my walls about 2 inc away from the concrete walls. The basement walls are about 4 ft high, then they go in about 2 inc then up again another 3 1/2 feet. The walls are sort of an l shape, I was thinking maybe if I insulate the ceiling, it will make the above floor feel much warmer?
Thanks Guys, Thanks Atlantic
Should I insulate an attached garage? pbkid Building & Construction 11 07-09-2011 03:31 PM
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 04:41 PM
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 09:32 PM
How to insulate under a shed floor 6n165 Building & Construction 3 01-04-2008 12:55 PM
Best way to insulate around a breaker box? Chip718 Building & Construction 5 11-15-2006 10:28 PM
