Old 08-05-2010, 11:02 AM   #1
Insulate crawl space ceiling?
Crawl space is unheated. No insulation under the main floor. Live in Canada so it is cold in winter. Is it worth the cost to insulate?
Thx
Tom
tomdward is offline   Reply With Quote
Old 08-05-2010, 12:34 PM   #2
Done right, eventually all insulation projects are worth the cost, but sometimes that can be a long way inbetween.
What is the floor space of you house and does the crawl space lie underneath the entire main floor?
Is the main floor level with the ground surface or above/below it? More to the point, what temperature is the crawl space in the winter?
Troglodyte is offline   Reply With Quote
Old 08-05-2010, 01:08 PM   #3
Crawl space is under entire main floor which is 1300 sq ft
Main floor is above ground level
Just bought so do not know crawl space temp in winter
Thx
M
Old 08-05-2010, 09:01 PM   #4
Can't put a price on comfort .
High Gear is offline   Reply With Quote
Old 08-05-2010, 09:07 PM   #5
Wire Chewer
Red Squirrel's Avatar
Try insulating just the rim joists as a start, and maybe the walls of the crawlspace. I want to do this eventually once I have the money. My rim joists are partially insulated but it's fiberglass, which gets moldy. Need to use foam.
Old 08-05-2010, 09:30 PM   #6
the Musigician
DangerMouse's Avatar
I've insulated all of the crawl space outer walls I've built here, and covered them with wood on the inside as well to 'box it in' and seal the areas.
We'll see how much nicer it is here this winter.... Po) It wasn't bad down there last winter, around 40° to 50°, it never got below freezing.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 08-06-2010, 12:27 AM   #7
Moderator
It sounds like you have a vented crawl space now, check with your local B.D. before you close it off. If in a very cold area, you could melt the perma-frost and feel your house settle. You need an exhaust for air changes, per code. Depends on the amount of supply ducts below. May need to cover the foam board.
http://www.advancedenergy.org/buildi...l%20Spaces.pdf
http://www2.iccsafe.org/cs/committee...E_06_64_07.pdf
http://www.eere.energy.gov/buildings...s/db/35379.pdf
Do you have plastic on the ground?
Be safe, Gary
Clothes taking longer to dry?
Old 08-06-2010, 09:33 AM   #8
Plastic on the ground is important to stop moisture from seeping up.Any plumbing in the space will need protection from freezing.
daveb1 is offline   Reply With Quote
water in crawl space need advice puma80 Building & Construction 2 04-08-2010 11:07 PM
Whole in Crawl Space Wall? Water Problem? - Picture! donaldp General Discussion 1 03-26-2010 09:52 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
Unvented crawl space insulation ehardman Building & Construction 3 01-13-2009 01:44 PM
Insulate concrete flor above open crawl space... JamesEric Building & Construction 12 11-25-2008 09:43 AM
