Insulate Basement Walls, 1/2 Concrete / 1/2 Wood Frame - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 11:13 AM   #1
Insulate basement walls, 1/2 concrete / 1/2 wood frame
I am goint to finish off my basement and plan on framing new walls inside the concrete wall. I'd like some input on where to put the insulation and vapour barrier. I would like to keep the new walls as close to the concrete as possible. It currently has insulation/poly in the top 5' of the walls which are wood frame and nothing on the concrete bottom third. I have attaced a sketch showing what I have now. Any advice is much appreciated.
rovers1973 is offline   Reply With Quote
Old 04-25-2010, 05:50 PM   #2
DIY staff
Rewards Points: 7,174
I use craft faced bats with the vapor barrier facing the warm side of the wall--don't be concerned with the existing insulation--that's far enough away to allow a bit of air circulation.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Insulating poured concrete basement walls Dude Building & Construction 0 03-03-2010 12:24 PM
Basement Insulation Plan mcwolfe6 Building & Construction 9 03-01-2010 10:10 AM
Framing in basement attached to concrete blocks, how to insulate? drnormie Remodeling 11 01-21-2009 05:40 PM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 12:21 PM
