Insulate A Basement Walkout Door? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-25-2008, 08:07 AM   #1
Insulate a basement walkout door?
Anyone have tips on the best way to insulate a new wood door?
Customer wanted the old one replaced with a shiplap identical to the old one. I used pressure treated that was pretty dry and then stained and sealed it. Since the walkout has 8 cement stairs leading out with another door at ground level, also PT I've got a dead air space between the two and it's pretty air tight and dry.
The issue will be with the 0* weather we get. That basement door will be cold. The basement isn't ever going to be finished so that's not an issue.
You thoughts?
Shamus
Shamus is offline   Reply With Quote
Old 09-25-2008, 09:38 AM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Have you ever felt a warm door with below zero weather?
The other door may be the one that should be better insulated/weather stripped since it really sees the weather.
concretemasonry is offline   Reply With Quote
Old 09-25-2008, 12:01 PM   #3
I agree, but that door is split down the middle and hinged on both sides.
The basement door is one piece. I might just use a piece of foil faced foam board. I'm concerned about the lap joints, the wind here blows pretty good.
Just wondwering if anyone has used something different or a better solution.
Shamus
Old 09-25-2008, 12:10 PM   #4
Rewards Points: 1,910
Get a really good insulated door and put the desired exterior on it.
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Walkout Basement Door allworld Building & Construction 1 06-17-2006 01:50 AM
