-   -   Insulate a basement walkout door? (http://www.diychatroom.com/f19/insulate-basement-walkout-door-27336/)
Shamus 09-25-2008 07:07 AM
Anyone have tips on the best way to insulate a new wood door?
Customer wanted the old one replaced with a shiplap identical to the old one. I used pressure treated that was pretty dry and then stained and sealed it. Since the walkout has 8 cement stairs leading out with another door at ground level, also PT I've got a dead air space between the two and it's pretty air tight and dry.
The issue will be with the 0* weather we get. That basement door will be cold. The basement isn't ever going to be finished so that's not an issue.
You thoughts?
concretemasonry 09-25-2008 08:38 AM
Have you ever felt a warm door with below zero weather?
The other door may be the one that should be better insulated/weather stripped since it really sees the weather.
Shamus 09-25-2008 11:01 AM
I agree, but that door is split down the middle and hinged on both sides.
The basement door is one piece. I might just use a piece of foil faced foam board. I'm concerned about the lap joints, the wind here blows pretty good.
Just wondwering if anyone has used something different or a better solution.
jogr 09-25-2008 11:10 AM
Get a really good insulated door and put the desired exterior on it.
