Old 11-13-2010, 03:35 PM   #1
Insulate basement garage ceiling under living area?
I'm new and this is my first post here, so please be gentle with me.
1931 airplane bungalow with a single-car garage attached to the basement which has stone foundation walls on two sides. There is simple drywall on the other sides separating the basement section from the garage to meet code, so the garage is technically unheated but gets some heat from the basement (which is unfinished). It never gets to freezing in there, but it does get chilly.
The joist bays have no insulation and the garage is directly below living space in the first floor of the house. If I were to buy bats and install them in the ceiling of the garage, would this help to keep my feets warmer in the winter, or am I just putting a bandaid on it?
I know nothing of actually doing this, and this is my first foray into finding advice on the subject.
beckydewit is offline   Reply With Quote
Old 11-13-2010, 03:43 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
It should actually be spray foamed to seal out CO from the living spaces.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 11-13-2010, 03:48 PM   #3
Thanks, Greg. Will that insulate it from the cold as well?
Old 11-13-2010, 03:54 PM   #4
gregzoll's Avatar
It IS insulation. Just depends on what the locals that do it recommend.
Old 11-13-2010, 04:01 PM   #5
K. I assume that, by "locals," you mean local professionals who spray in foam. I don't know anything about that.
My CO detector has never detected any CO, and I don't know what the code here is for that. I'll have a city inspector here on Monday so I'll ask him.
In the meantime, if it doesn't need to be sealed for CO, is it possible that bats would do the job for cold?
Old 11-13-2010, 06:23 PM   #6
gregzoll's Avatar
Home CO detectors do not detect the lower amounts, that over time cause more harm if in that area to allow prolonged exposure. If you go with batts, you still will need to use 5/8" gypsum and tape the joints.
Old 11-13-2010, 06:26 PM   #7
joed's Avatar
It will need a vapour barrier on the Hot side(top of bays) and fire rated drywall after the insulation. Spray foam is a vapour barrier and insulation all in one. It is more expensive but it is the best way to do it.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-13-2010, 08:02 PM   #8
Master General ReEngineer
Bondo's Avatar
Ayuh,... If you want the Ultimate in warm feet,...
Install radiant heat under the floor 1st,.. Then insulate, 'n seal it up...
Old 11-13-2010, 09:54 PM   #9
Ah. Is there really that much CO that infiltrates with one car that spends a maximum amount of about 30 seconds (in and out) inside with the engine running with the outside door open? We've been living with it for 20 years and I'm not sure, but I'm pretty sure none of us has suffered.
Like I said, I'll ask the inspector on Monday about it.
There are many things up in parts of the bays, like outlets and pipes and things that have to get gotten to at times - can the foam be sprayed around these things?
I'd love to have radiant heat, I just can't afford to do something like that right now. We've just shot our wad on electrical upgrading and customizing and it will take some time to save up more money for such things. This is why I'm asking about using batting.
I really appreciate all of your answers and I thank you.
Old 11-14-2010, 08:23 AM   #10
gregzoll's Avatar
Get the measurements, and then go to Home Depot or Lowe's and price out Plastic Sheathing for the vapor barrier, unfaced batts (May need R-38 or higher), and 5/8 Gypsum with the mud & tape. You may find out that the cost is on key with Spray Foam for the space. As for around ceiling boxes, they know how to spray around. You should not have to get up in the bays to mess with anything if it was done correct to begin with.
Old 11-14-2010, 12:59 PM   #11
Comparison pricing. Always a good idea. It may indeed be on key with foam, plus I'd save trips back and forth to HD or Lowe's and the labor involved, not to mention the savings in frustration.
Thanks for your help, Greg.
FInished basement area too cold richardnml HVAC 0 06-19-2010 02:39 PM
Lighting Options for a dropped ceiling basement markronz Electrical 11 04-20-2010 03:20 PM
More Basement Dropped Ceiling Installation Questions markronz Remodeling 7 02-28-2010 04:47 PM
garage ceiling moisture chezseans General Discussion 4 02-08-2010 03:35 PM
Drywall Garage Ceiling Recommendations jsjames Building & Construction 6 08-22-2007 04:47 PM
