Installling Basement Egress Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-10-2010, 10:32 PM   #1
JohnnyB's Avatar
I am in the planning stages of refinishing my basement. I have a handfull of questions on egress windows. The wall I want to install two windows on is 39' 4" long. Both windows will be atleast 3 feet from the corner's. I need to put two windows in because I want two bedrooms. The fondation is largely exposed so I will not need to dig a well to meet the 44" requirement.
How much should I expect to pay to rent the saw?
Is it as straight forward as I think? Far as I know I just measure, cut, and breakup the chunk.
How do I know if I need to use a header?
How much is an average size egress window going to cost?
On the prices. I know it hard to say, but I live in the St. Louis Area, and just need ballpark numbers to know what to plan for.
Thanks for any help you guys can provide.
John
JohnnyB is offline   Reply With Quote
Old 04-10-2010, 10:46 PM   #2
Rewards Points: 5,336
For the rental price, you would go to the rental store, tell them the job details and they would tell you what saw to use and the dailey rental fee.
For the window, you would find out what size you need and go to a window store and ask the salesman how much it will cost.
You will need a header.
Ron
Old 04-11-2010, 08:15 PM   #3
Concrete & Masonry
Rewards Points: 530
Is the foundation poured concrete or cocnrete block? If it's the former, it isn't as easy as just hitting it a few times with a sledge. The whole job in general isn't really for a novice IMO. I would recommend looking for a concrete sawing outfit in your area, as they can make short work out of it for you. Good Luck.
jomama45 is offline   Reply With Quote
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 09:56 AM
Basement Windows maryr006 Carpentry 2 08-16-2009 10:52 PM
Basement windows in masonry walls dave11 Building & Construction 1 03-20-2009 09:28 PM
Windows: RO sill height and egress question. iMisspell Building & Construction 3 10-25-2008 01:55 PM
Insulating basement windows Keyo77 General DIY Discussions 3 01-06-2008 07:33 PM
