Installing Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-13-2007, 01:21 PM   #1
Rewards Points: 152
Installing Windows
I noticed that some manufactures do not recommend installing flashing tape on the bottom of the window over the nail flange.
Do you recommend?
Also some say that sealant should be applied along the edge of the rough opening over the tyvek. Is this necessary?
Thanks!
sandyman720 is offline   Reply With Quote
Old 08-14-2007, 07:28 AM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,286
A membrane goes over the rough sill before the window is installed and the nailing flange gets nailed through that. This will allow any water that may get trapped a way out.
Somebody correct me if I'm wrong but I think the only flange that gets covered with a membrane is the top of the window.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-14-2007, 07:32 AM   #3
Agent 000
SecretSquirrel's Avatar
See this construction detail at the Grace Vycor site;
http://www.na.graceconstruction.com/...00.html&did=26
SecretSquirrel is offline   Reply With Quote
Old 08-14-2007, 07:50 AM   #4
Rewards Points: 152
What about the sealant around the jams?
Old 08-14-2007, 08:07 AM   #5
Agent 000
Yes, put a bead of silicone sealant around the flange of the window or around the rough opening so the flange will come in contact with it.
Old 08-14-2007, 08:58 AM   #6
Rewards Points: 152
So put it on the tyvek around the windows?
Old 08-14-2007, 09:17 AM   #7
Agent 000
See this Tyvek document. Look at page 6 and they illustrate the sealant going around the perimeter of the rough opening and there's also some flashing details. One point of contradiction though... Dupont says not to apply sealant across the bottom sill flange. Anderson window installation instructions says you do. I would refer to the recommendations of your window manufacturer for the specific instructions on this. Not knowing who's windows you are using I went on the Anderson guidelines.
http://www2.dupont.com/Tyvek_Constru...ing_K16280.pdf
Old 08-14-2007, 10:37 AM   #8
Rewards Points: 152
What is the best type of caulk to use for this? Clear Silicone that can be used with Vinyl?
Old 08-14-2007, 11:23 AM   #9
Agent 000
http://www.dap.com/product_details.aspx?product_id=292
Old 08-14-2007, 11:42 AM   #10
I have gas!
I thought it made more sense to cover up the nailing flanges on the sides of the window. This Old House got it wrong on the Carlisle project.
Old 08-14-2007, 12:35 PM   #11
Agent 000
What did they do... leave them exposed?
Here's a picture of how not to flash. It's a beaut ain't it? Tyvek ripped, top of the window flashing all crumbled up, sheathing exposed. Boys, it's hard to find good help these days.
Old 08-14-2007, 12:55 PM   #12
concretemasonry's Avatar
Rewards Points: 2,570
Clutchcargo -
Maybe the This Old House is one factor in the rediculous number of improperly installed windows (estimated at 60-70%). Unfortunately, you do not know they are improperly installed until it is a few years too late.
For those that are interested, there is a program to become a certified window installer. Some builders will only sub out to certified installers or they invest the time and money to get their own people trained and certified. The certification class is supported by the window manufacturers and is provided for a fee ($300-$400??? when i took it) by independent construction oriented firms.
concretemasonry is online now   Reply With Quote
Old 08-14-2007, 01:34 PM   #13
I have gas!
They covered the rough sill, then covered the left and right trimmers, installed the window, then put the last piece over the top flange. Maybe there was some other reason they did it that way. They were using the pre-fabricated panel construction. It looked like they didn't use a house wrap on that portion as well.
Originally Posted by concretemasonry View Post
Clutchcargo -
As soon as the adhesive starts to let go, right?
Novice question: Installing windows in wood sided home...(pic) Dr. Jim Building & Construction 5 07-06-2007 07:33 PM
new windows juliejules4 HVAC 12 12-06-2006 02:37 PM
Installing Windows after Drywall??? jeepwillies Building & Construction 9 11-22-2006 11:30 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
