Installing Window In Stone Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-24-2009, 04:59 PM   #1
Question
Installing window in stone wall
I am bringing a 17?? stone house back to life. the walls are entirly made of stone and are .8 meters thick at some points. How would I proceed with installing a window, without risking of bringing down the wall.
regards.
nina09 is offline   Reply With Quote
Old 08-24-2009, 05:20 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Nina, You get the prize for most challenging DIY Project, especially for a wall 32" thick. I doubt any DIY'r at least in the US has taken on a solo job job like that.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-25-2009, 05:59 AM   #3
i have done it in a block wall but not stone so I dont know if it is the same
clasact is offline   Reply With Quote
Old 08-25-2009, 06:07 AM   #4
I would think you need to install a nailer frame around the opening. Use tapcon. Drilling in stone is a bit tougher than block, but can be done with a good hammer drill and a sharp bit.
Old 08-25-2009, 11:07 AM   #5
Rewards Points: 582
Can you put a photo of the stonework on? It'a a job that can be done, but I would need to see the type and bonding of the stonework.
stuart45 is offline   Reply With Quote
Old 08-25-2009, 12:27 PM   #6
Sleeve Anchors
Concrete fastener companies will not have testing or any holding values for stone because all stone is different. I use sleeve anchors that are designed for brick and block when I need to fasten something to anything that is not solid concrete. There is alot of info on the sleeve anchor on http://www.sleeve-type-anchor.com/ The Tapcon may work but I have had experiences where old stone would crumble when I tried to use the tapcon screw.
Bronx is offline   Reply With Quote
Old 08-25-2009, 02:42 PM   #7
Rewards Points: 190
not a DIY project?
I consider myself a fearless DIYer but I think that is a job for a skilled pro. 32" stone has tremendous weight. You could be killed if you make a mistake. You will need a lintel over the window which if stone would also be very heavy and need equipment to place. Last year a group of volunteers including myself built an outside toilet for an 1813 stone building. At first we thought we needed handicapped access from inside the building and we were going to have the opening cut by a professional contractor. Later we learned because it is an historical building we could get a waiver and use an outside door.
Can you post pictures? It would be interesting to see.
zircon is offline   Reply With Quote
Old 08-25-2009, 04:19 PM   #8
Rewards Points: 4,644
that's a GREAT looking crapper
Old 08-25-2009, 06:50 PM   #9
Rewards Points: 190
And it's only a one holer
Old 08-27-2009, 08:55 PM   #10
Registered User
Rewards Points: 5,514
Trying to meet code with the gutter? But no downspout?
Be safe, G
Old 08-27-2009, 09:08 PM   #11
Rewards Points: 190
have faith
It's around the corner.
Old 08-27-2009, 10:34 PM   #12
Gutters are code ??
Old 08-28-2009, 12:03 PM   #13
Registered User
Very tricky, fooled me! I figured it was a City's Historic Building (Commercial), they would be required to use gutters as they have on the main building attached the the cute little one-at-a-time house. In residential, gutters are only required "If soils are expansive or collapsible, roof drainage must discharge minimum 5' from footing or to approved drain system...IRC 801.3 (or you could build 5' roof overhangs, lol).
Be safe, G
Tags
installation , stone wall , windows
Help: Installing Faux stone over interior concrete surface cips General DIY Discussions 21 12-27-2009 11:42 PM
Installing Window with no fin or moulding sendres Building & Construction 2 05-26-2009 03:53 PM
Installing stone on fireplace with NON 90 degree corners? Kiwi. Remodeling 4 02-11-2009 05:39 PM
stone wall: estimating cost wombosi Landscaping & Lawn Care 2 11-28-2008 07:49 AM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
