Installing Window With No Fin Or Moulding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-26-2009, 12:35 PM   #1
HandyMan Engineer
Question
Installing Window with no fin or moulding
Here's the scoop.
The club house of the Rugby club I belong to was in need o f serious TLC. One item was a broken window that had been boarded up (poorly) for two years. Any way got rid of the mold and replaced the entire wall section where the window was located. In the mean time someone else is sourcing the replacement window. Well I understand they got a great deal, but now I have to install it and its not like anything I've seen or at least dealt with. No fin or brick moulding. Possibly it was for a msonary wall, though I have no experience with it. Looking for advice as how to install it and get it water tight.
4x6 Window Reinforced with Aluminum frame.
Vinyl Siding
2x6 construction
Use Flashing tape as normal
Use Shims, drill Holes, and screw window flush to outside of J-Trim.
Add Drip cap over window.
Use backer Rod and sealant between window and JTrim?
Not sure what additional steps I should take?
It's a bad location for water with no Eave above and on the prevailing wind side for driving rain.
sendres is offline   Reply With Quote
Old 05-26-2009, 03:44 PM   #2
I would build a window box frame out of vinyl wood make it 1/8 to 1/4" larger inside than the replacement window. Install as a standard new construction window (flashing,insulation, etc). Install vinyl outside stops and caulk the inside edge. Slide the replacement window in against the caulked stop, install side screws, insulate around the sides, and then install the inside stop.
hayewe farm is offline   Reply With Quote
Old 05-26-2009, 03:53 PM   #3
Old School
Willie T's Avatar
Click HERE. and read Page 5
Willie T
Installing vent in glass block window jasoncw Building & Construction 6 09-27-2009 10:57 AM
Installing window AC in metal frame sato HVAC 10 08-08-2009 09:15 AM
Installing window questions bakerhouse Remodeling 4 05-18-2008 01:22 PM
Installing New Bathroom Window 1L243 Building & Construction 4 01-26-2008 11:40 AM
