Installing Wall Insulation Bats - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-01-2008, 01:48 PM   #1
Question
Installing Wall insulation bats
I am installing wall insulation in my attached garage. My question is "which way" should the paper be on the house side?
I *think* the paper should be towards the house for vapor barrier and for the outside walls the paper towards the garage.
I know this won't be a perfect vapor barrier, but it's what I got.
Any thoughts?
Larry
lrr81765 is offline   Reply With Quote
Old 10-01-2008, 03:04 PM   #2
RippySkippy's Avatar
Your right...paper/vapor barrier always goes to the "warm" side.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-01-2008, 05:22 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
Correct!! the vapor barrier always faces the warm or heated side of the room its being installed in.
Old 10-02-2008, 07:51 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Warm in winter side
Old 10-02-2008, 02:44 PM   #5
Rewards Points: 1,910
Unless you live in the hot humid south. Then I beleive vapor barrier goes on the outside. Chances are your local code will require you to do it a certain way. A quick phone call to building dept will tell you.
Water seeped through tiles in shower, wall ruined, need help. doogie88 Building & Construction 39 10-07-2008 05:13 PM
Installing New Wires In Wall? madcitysw Electrical 5 01-14-2008 09:08 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 05:50 PM
