Installing Vinyl Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 01:29 PM   #1
Rewards Points: 197
Installing vinyl windows
I'm at the point of installing new construction vinyl windows in my house and I am uncertain about two aspects of the installation.
1) Caulk behind the window fins; yes on no ?
The manufacturer says yes, but in an article on BuildingScience.com, it states that it is "unnecessary and dumb".
With proper flashing, it does seem kind of redundant; sort of like wearing a belt with suspenders.
What say ye ?
2) Nail the fins tight or nail loose like vinyl siding ?
The manufacturer say loose to allow for expansion, but even when nailed loose, I wonder how the vinyl can expand and contract given the orientation of the nail slots. In other words, the side fins have vertical slots, supposedly to allow vertical expansion of the window, however, the top and bottom fins have horizontal slots which would seem to interfere with the vertical movement of the window.
The same could be said about the horizontal movement of the window. (Top/bottom slots inhibit vertical movement; side slots inhibit horizontal movement)
What say ye to this ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 03-25-2011, 02:16 PM   #2
Rewards Points: 2,238
Caulking behind the nail-flange is optional - you can use "Tyvek" tape
(or, something similar).
Shim the windows - bottom and sides - using cedar shims.
Make sure the space between the window and the framing has
adequate insulation installed - un-faced fiber glass, foam, caulk.
Get the window square and plumb - then nail the flanges.
rossfingal
rossfingal is offline   Reply With Quote
Old 03-26-2011, 12:50 AM   #3
Registered User
Rewards Points: 4,910
Read this on page 8; http://docs.google.com/viewer?a=v&q=...WrZBbBZoIUXgxw
Tyvek tape is good for Tyvek seams. Use a low-expanding foam around the gaps;
Airflow performance of building ... - Google Books What type of;1. house wrap? 2. siding? 3. sheathing?4. where are you located? 5. What for head flashing?Gary
Vinyl replacement windows. joefromcal Building & Construction 8 02-20-2011 10:54 PM
Best practice when capping vinyl windows in brick rugby style Remodeling 2 01-18-2011 02:13 PM
installing high basement windows denemante Building & Construction 3 08-27-2010 05:18 PM
Frost on interior of vinyl windows d.sharkey Building & Construction 8 07-06-2009 07:25 PM
Installing Windows after Drywall??? jeepwillies Building & Construction 9 11-22-2006 11:30 AM
