Installing Vinyl Siding Without Snap Lock Punch? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 08:19 PM   #1
Rewards Points: 152
Installing vinyl siding without snap lock punch?
Im installing the vinyl siding in my shed. I dont want to spend $20 on a snap lock punch that i would use only once. Can i make those rivets without the tool?
humberguy is offline   Reply With Quote
Old 07-14-2012, 10:19 PM   #2
Rewards Points: 14,306
What rivits? It punches out a rectanguler shaped hole leaving a tab sticking out.
People has been installing siding for a long time before that tool ever came out.
The only time it gets used is where it snaps in under a window where the utility or undersill trim is. But I'd be willing to bet that at least 80% of siding jobs never used the snap lock on the job.
I have several of them and use them all the time on my trim coil, last piece of siding on the sides of the house as well as under the windows.
May be why I've never had to go back and fix a loose piece of material.
jaydevries (07-14-2012)
Old 07-14-2012, 11:13 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
snap lock punch is a very old metal working tool not a recent one,i would follow the directions the vsi manual provides for you instead of jury rigging
20 bucks is not too much
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
mae-ling (07-15-2012)
Old 07-14-2012, 11:31 PM   #4
I believe he's talking about this tool, not one for metal.
http://www.malcoimages.com/products/...ock-punch-sl5/
Old 07-15-2012, 07:58 AM   #5
the metal ''crimper'' will also work,and my advise was for the op not a seasoned pro that has developed a system that works for him
Old 07-15-2012, 11:14 AM   #6
Rewards Points: 2,212
Yep $20 is way worth it compared to your siding falling out.
mae-ling is offline   Reply With Quote
need advice installing soffit vents in vinyl siding tspoon84 Roofing/Siding 4 01-05-2012 09:20 PM
Vinyl Siding Help Needed swiederin Building & Construction 4 10-24-2011 09:02 PM
Another vinyl siding question Arky217 Building & Construction 7 10-10-2011 06:34 PM
Removing vinyl trim around entry door without breaking vinyl siding 2vets Building & Construction 1 10-18-2010 10:28 AM
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 09:32 PM
