Installing Tyvek House Wrap - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 10:01 AM   #1
installing tyvek house wrap
I am adding 2inches of strofoam to the exterior of my home. The walls are 2x4. I want to use tyvek as a air barrier. My question is where do I apply the tyvek. On the walls prior to the styrofoam or after the styrofoam is applied
Bill Mitchell is offline   Reply With Quote
Old 02-19-2011, 12:03 PM   #2
Registered User
Rewards Points: 5,514
Welcome to the forum!
1. What type of siding will go on the outside?
2. Type of insulation in cavity?
3. Type of sheathing?
4. Location?
Gary
Old 02-19-2011, 12:53 PM   #3
concretemasonry's Avatar
Rewards Points: 2,608
Bill -
Tyvec is not an air barrier. It is water barrier that allows air to pass through.
Dick
concretemasonry is online now   Reply With Quote
Old 02-19-2011, 06:07 PM   #4
Rewards Points: 177
Originally Posted by concretemasonry View Post
Bill -
Dick
Actually that is wrong. It is an air barrier. Air will not pass through it. It is also a liquid water barrier. What it does allow to pass is water vapor.
http://www2.dupont.com/Tyvek_Weather..._homewrap.html
paul100 is offline   Reply With Quote
Old 02-19-2011, 09:22 PM   #5
According to the site referenced:
Tyvec "blocks excess water from entering the wall". Excess water is moisture the is free water (liquid state) and not in vapor form. - That sure sounds like a primary moisture barrier which is used in most design standards and codes. The purpose of the primary moisture barrier is to shed water downward to an exit on the EXTERIOR.
Tyvec "allows moisture vapor to pass through the to help the drying of the wall". That means it is not a vapor barrier, but breathes, so the vapor barrier can performed as required, which is on the warm side of the insulation unless the rigid insulation is the vapor barrier.
The reference citation is really non-technical description written for people other than engineers, architects and even code officials.
Just a side note: - there is not such thing as a vapor barrier, but in our loose building codes it is set at an arbitrary level of perms. As an example, the fraction of a mill can reject a material, but there is no reference for the nails penetrations, edge sealing or even uniformity of the material thickness. - It is really just a design concept with a short-hand definition of real performance.
Dick
Old 02-24-2011, 07:00 PM   #6
4. Location?
Gary
wall will be covered with vynal siding
Wall has fibreglass insulation and is sheeted with 5/16 plywood.
my house is located in Saskatchewan
Old 02-24-2011, 09:08 PM   #7
Registered User
Something to think about; http://www.greenbuildingadvisor.com/...istive-barrier
Gary
Old 02-25-2011, 08:12 AM   #8
EZHangDoor
My opinion would be to have the building wrap on the very exterior of the building. This way you can properly install the building wrap as a drainage plain also. If you are using foam, you would need to use plastic cap nails to hold the building wrap on.
EZHangDoor is offline   Reply With Quote
installing heating unit for a flat roof house gcampbell29 HVAC 6 02-23-2009 06:34 AM
House Wrap - removing vinyl siding to install wrap roo747 Building & Construction 9 11-01-2007 05:27 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
house wrap? Neil_K Building & Construction 3 12-22-2004 09:14 PM
