Installing Trim Where Ceiling Meets Wall..... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-31-2008, 09:15 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Installing trim where ceiling meets wall.....
I was thinking of installing a small trim like crown moulding, not as wide as crown moulding, where the ceiling meets the wall.
Basically, so I can avoid taping there.
How would I attach it on?
The one I have seen is made of MDF board. Do I attach it with those really skinny little nails, that pretty much have no head? But how would I sink them into the trim?
(I assume you don't have to tape the corners if you install moulding?)
yummy mummy is offline   Reply With Quote
Old 04-01-2008, 12:09 AM   #2
wfischer's Avatar
I love girly terminology
Those would be finishing nails, and yes, that's what you'd use.
What you need here is a nailset:
http://www.stanleytools.com/default....GORY=NAIL+SETS
Note that there are different size nailsets that correspond to the size of the nail you're using. The point of the nailset sits in a divot in the head of the nail, so that when you pound the nail in, the nailset doesn't slip off (at least, in theory) and put a hole in your trim.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape!
wfischer is offline   Reply With Quote
Old 04-01-2008, 08:17 AM   #3
Thanks very much for the information. I have become so knowledgeable at this forum.......
Old 04-01-2008, 11:40 AM   #4
Custom Cabinet Maker
Yummy!!!!!!!!! What the heck am I going to do with you? hmmmm did my keyboard say that? bad keyboard. Yes Finishing nails, nailset, nail into the top plate. Next question you are going to be asking is how to make the corner joints, so I will wait to answer until you get to the problem
skymaster is offline   Reply With Quote
Old 04-01-2008, 09:22 PM   #5
Yes Jackie, I have been thinking about those corners.
I imagine I would mitre them together. I have a compound mitre saw, and it does angle cutting. But how will I know if they will fit in right?
How do I know what degree angle I have? There must be some sort of secret.
Old 04-01-2008, 09:45 PM   #6
will PM ya LOL
Old 04-02-2008, 09:25 PM   #7
You can get a Senco nailer for cheep - it will save you a lot of headaches (and time)
nadonailer is offline   Reply With Quote
Old 04-04-2008, 09:29 PM   #8
remodeling pro
You still want to tape the corner for two reasons. First for fire protection and code, and secondly, because if you are using factory edges of drywall at the ceiling/wall corner, you will be installing the crowm moulding within the factory depressed tape seam, and the depressed area will be very ugly when painted. Since you seem to be doing a good bit of ongoing improvement projects, it would be well worth the money for one of the little compressor/multiple gun kits readily available at the big boxes. While not trade tough models, they are adequate for typical HO projects; not only saving you tons of aggravation over hand nailing, but giving much better results.
troubleseeker is offline   Reply With Quote
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Ceiling Meets Wall DIMDAL Painting 3 02-24-2008 03:23 PM
Installing New Wires In Wall? madcitysw Electrical 5 01-14-2008 08:08 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
