Old 07-12-2009, 03:22 PM   #1
Installing T&G with crown on ceiling
I have installed 1x8 T&G several times in the past without too much hassle, but my resent job much of the T&G has a crown on the groove side which makes it very difficult and time consuming to install. I am face nailing using a gun with 15 gauge nails. Any Ideas???
Rionewberry is offline   Reply With Quote
Old 07-12-2009, 03:53 PM   #2
You should be nailing through the tongue to keep it tight. If you are having a problem with getting the joints tight, I usually drive a chisel or shark grip into the joist to and then bend it into place. Sometimes having an extra pair of hands makes all the difference with the stubborn pieces.
Josh Jaros Remodeling in The Woodlands, Texas
jaros bros. is offline   Reply With Quote
Old 07-13-2009, 05:01 PM   #3
I have installed T&G in several rooms without too much hassle, but in my latest project much of the 1x8 T&G has a crown on the groove which makes it very difficult and time consuming to install. So how do you hold one end in strong enough to force the other end in and is there a special tool to do that?? I am face nailing using a gun with 2 1/2 " 16 gauge nails. Thanks for any ideas!
Old 07-14-2009, 10:46 PM   #4
Remodeling Contractor
Can you explain "crown"? Are you trying to put crown molding up on top of the T&G?
DaVinci is offline   Reply With Quote
Old 07-15-2009, 11:54 PM   #5
You are in luck. I just got finished with the same project and had the same trouble. I always say I get really good at it about the time I get done with it. The answer is clamps. They make long ones that are adjustable and will hold several pieces of t/g at once. You have to pull the crown tight against the last board or you can push it tight against the last board. They make a set of clamps that do both at large home improvement stores for about $20.00. They have rubber protectors on them to protect the wood. After I found these I can't remember how I did without them. Also are great for straightening rafter tails in exposed porches etc. Get the kind that will push or pull. Good luck.
joan smith is offline   Reply With Quote
Old 07-16-2009, 11:43 AM   #6
I am installing 1x8 tongue and groove on a ceiling. The T&G has an upward arch (crown) on the groove side. The lumber is arched along it's entire length so trimming ends does not help. After nailing in one end, even with 3 nails, it pops out as you work your way down the board, and on many I couldn't figure out how to get enough pressure to wedge in far end even using a pry bar. Using a hammer and board, the T&G would just pop right back out.
Old 07-16-2009, 11:49 AM   #7
Thank you, next time I'm at the hardware store I'll look into that.
Old 07-16-2009, 01:38 PM   #8
Xtreme DIY'r
2 Threads on the same subject have been merged into this thread
Thanks - Dave
Old 07-16-2009, 04:14 PM   #9
Rionewberry,
Could you go to this link, look at the illustration and lets see if this clears anything up.
http://www.popularwoodworking.com/ar..._Crooked_Wood/
Also:
What is the material (pine, oak, cherry,____)?
Are your boards running parallel to your ceiling joists or perpendicular?
Is there existing drywall on the ceiling?
I am assuming that if there is a "crown" on the grove side there is also a "crown" on the tongue side?
Paul
Old 07-17-2009, 10:25 AM   #10
I think these are called ratcheting bar clamps/spreader. You may have to tack a block of wood on rafters to get leverage. Mine are very long 2 or 3 feet. Good luck.
Old 07-17-2009, 10:36 AM   #11
RippySkippy's Avatar
The last ceiling I did like this we were able to move the pieces together with a chisel driven into the ceiling joist then pry against the tongue to snug it up.
Iit sounds like you have the need to move it further than that...would something like the BoWrench work?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 07-17-2009, 11:48 AM   #12
You are doing this the hard way. Load it up and take it back and get some straighter material!
framer53 is offline   Reply With Quote
Old 07-17-2009, 12:06 PM   #13
47_47's Avatar
Best advise so far.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is online now   Reply With Quote
Crown moulding: Flat ceiling to angled wall question RP31 Carpentry 19 10-30-2012 04:18 PM
Crown moulding with a vaulted ceiling? cstrat Carpentry 34 06-17-2011 07:51 PM
Crown molding - uneven ceiling jelly Carpentry 9 01-05-2010 07:24 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Installing T&G birch ceiling NeedHelp Building & Construction 6 12-29-2007 09:09 AM
