Old 10-28-2007, 10:31 AM   #1
installing a support beam
I am opening a load bearing wall and need to determine the size of support beam. This is a two story house with an unused attic (will never be used). I am replacing the wall on the first floor. The second floor is all bedrooms and baths. The span is 12 feet and I am hoping not to have any columns. This section is 12 feet of a total 30 foot house width.
What size beam do I need? I am looking at 2 2X10's right now.
Dominic is offline   Reply With Quote
Old 10-28-2007, 01:20 PM   #2
Darylh's Avatar
I myself would use a 3-1/2" x 14" microlam beam. If you go to the company that makes these in your area they will fix you up.A building inspector will know whar is code in your area.
Darylh is offline   Reply With Quote
Old 10-28-2007, 01:31 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Most large building/lumber supply companies can provide you with the exact dimensions you need, free of charge...if you purchase the beam from them and provide all the load bearing and design information of your home.
Most towns require an official "sign-off" from an engineer regarding something like that. A lumber company can also provide that as well.
There is one lumber company in my area that we use most often that charges only $50.00 for the engineer's stamp.
- Build Well -
Old 10-28-2007, 01:32 PM   #4
Power Gen/RS Engineer
You'll probably want to consult with a structural engineer to be safe. FYI, I wanted to remove approximately 9ft. of bearing wall on my first floor. Fortunately, I have an SE friend who ran the numbers and came up with a 1.9E LVL of 1-3/4" x 11-7/8." This too was a first floor application wherein this beam is carrying the 2nd floor joists, wall and ceiling. Keep in mind that you also need to consider what is below the area where the beam is to be placed. Remember that you are taking a load that is currently distributed over the length of the wall and changing it to a point load. In my case, I had to sister 2 existing floor joists and reinforce an existing timer beam below one of the new bearing points. At the other end, I had to build a shallow footing (in Illinois my basement floor is already below the frost line) in the basement and add a new post. All this additional work was in addition to the work of actually installing the beam but was required due to the manner in which the load was being re-distributed. Of course, my home is post/beam construction and was built in 1911. According to my SE pal, the house "does not work" by today's standards but alas, the structural systems in zillions of old homes are identical to mine.
Also, don't forget that you'll need to shore the ceiling prior to removing the wall. In my instance, the overhead joists are full span so I only needed to shore one side. If your joists are spliced over the wall that you are removing, you'll need to shore both sides. My SE friend gave me a good piece of advice to follow, a sort of test to know that the shoring is effective. Go to the center of the span to be removed and cut one of the bearing wall studs laterally with a demo saw. If the saw blade does not bind and the two pieces of stud are not bound at the cut surface, then the shoring is good and you can proceed with the demolition.
Also, if the ceiling framing is not already blocked over the wall to be removed, it's good practice to add some before you demo. Remember that you are disturbing the structure.
I know that you were probably hoping that someone would simply recommend a beam size and off you'd go. Honestly though, and I may be somewhat cautious, but this is one instance where you should probably seek out some real, professional input. An undersized beam may not present an immediate problem but over time, it will begin to sag leading to a whole host of problems like cracked walls, binding doors/windows, leaking plumbing, etc. And the cost to correct structural defects can be immense.
Finally, I'll leave you with a little story that my high school architectural drawing teacher once shared with me. He had this neighbor who hired a contractor to finish his basement. His friend's wife bought the furniture and found that the couch that she had selected was about 2 feet wider than the space between two adjacent pipe posts. So, the homeowner loosened the pipe at the beam connection and using a 5lb. hammer, slid it laterally the required 2 feet. What he didn't know/realize is that in doing so, he moved it off of the pier that was beneath the floor. 2 days later, he received a hysterical call from his wife saying that she couldn't open either of the 1st floor entry doors! They had to have someone come in and jack the house back to level which took a number of days to do. Following that, they had to have several trades come in to fix everything that had been damaged. Beaucoup dollars.
Anyway, good luck.
Jimmy
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Deck support beam has twisted Brian Ward Building & Construction 5 07-27-2007 12:03 PM
Floor Support Beam SlipperyPete Building & Construction 3 12-04-2006 06:55 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
drilling a support beam sdmotor Building & Construction 1 07-12-2005 11:51 PM
