Old 01-19-2012, 05:27 PM   #1
Installing Stone Veneer to cement board on a wall
I am installing a stone veneer (ledgestone, dry stack method) to a wall around my fireplace. I have the area framed and covered with 1/2" durock cement board. I was about to cover the cement board with roofing felt and then wire mesh so I could put on a 1/2" scratch coat. Doing some research online it appears this may or may not be necessary. Sounds like a lot of contractors just use thinset over the cement board and skip the felt/mesh/scratch coat.
I need the 1/2" scratch coat to make the dimensions of my corner pieces work out so I'll plan to use the mesh and scratch coat. However, do I need the "weather resistive" barrier (roofing felt)? Also, do I need to "seem" the cement board pieces (mesh tape and mortar) together or with the scratch coat take care of that?
If it matters, the stones I'm using vary in size from 3 inches to 21 inches in length and 1.5 inches to 5 inches in height.
Thanks.
Augy is offline   Reply With Quote
Old 01-19-2012, 08:36 PM   #2
Never mind...I went ahead and just installed the whole works since I had it on hand and it was what the mfg suggested. :-)
Old 01-20-2012, 07:17 AM   #3
Just an FWI augi the felt is meant as a moisture barrier which would not be need on an interior application.
Michael Olding is offline   Reply With Quote
The Following User Says Thank You to Michael Olding For This Useful Post:
Augy (01-21-2012)
Installing Stone Veneer Over Tile (see pic) bpdavis0 Tiling, ceramics, marble 10 05-29-2012 09:06 AM
Prep Concrete Block Wall for Natural Stone Veneer SCPete Building & Construction 2 03-06-2011 12:19 PM
Correct detail of preformed shower pan meet the cement board of a shower wall eyeglass Building & Construction 0 08-31-2010 03:31 PM
Stone veneer over foam board. rfjm58 Building & Construction 6 04-10-2007 07:40 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
