Installing A Steel Bathtub - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2009, 09:54 PM   #1
installing a steel bathtub
I'm installing a new bathtub which I've done before in another house. In the previous house the tub came with metal clips which attached to the tub and then were screwed to the studs. This new tub did not come with such clips.
Anyone know where I can get them those clips, or some other method to attach tub to studs.
bmancanfly is offline   Reply With Quote
Old 09-20-2009, 07:05 AM   #2
Remodeling Contractor
what does the directions say to do for your tub? If it is a steel tub, just set it on the floor. The drywall will lap over the flange. Nothing more is needed.
Old 09-20-2009, 08:52 AM   #3
like most things you buy at the big box store these days there are there are no directions.
A cast iron tub is big and heavy enough to put in place without securing. But the the lighter steel tubs need to be secured so that they don't move.
My old tub came with metal clips that attached to the tub flange and then could be screwed to the studs. No such clips came with the new tub.
Old 09-20-2009, 03:28 PM   #4
sounds like this tub is designed to sit on a 2X4 ledge you must provide around the three edges. then CBU over the flange.
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 12:23 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Refinishing bathtub or installing new one? gante General DIY Discussions 7 06-23-2008 03:54 PM
Installing a basement bathtub ... help please? njchan Plumbing 6 01-08-2008 11:51 AM
