02-02-2013, 06:25 PM
#1
installing a spiral staircase
I have a 34" x 74 long opening in floor. It is 94 in from top of floor below to next level where this hole is. can I install a spiral staircase in this opening and if so what size diameter do I start with
02-02-2013, 06:52 PM
#2
May be better of Googling Spiral stairs.
Almost any of the companys that sell them will be more then helpful to help design what you need.
02-02-2013, 06:53 PM
#3
Super Moderator
You need a wider opening----We have a some stair case guys here---one will be along in a minute--
Mean while,I'll google up something for you.--Mike-----
02-02-2013, 06:55 PM
#4
Moderator
You need a minimum clearance of 26" between the inside of the rail and the pole. Depending on the stairs you would need at least a 60" x 60" rough opening.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
The Following User Says Thank You to kwikfishron For This Useful Post:
02-02-2013, 06:56 PM
#5
Super Moderator
Metal Spiral Staircases and Custom Design Staircases by The Iron Shop
I tried to copy the page for you---but it did not work---this company has all of the opening sizes for your typical spiral stairs.
02-03-2013, 07:54 AM
#6
That is correct. We have a spiral staircase in our log home (bought a kit and installed it ourselves). Because of the wedge shape of the steps, it's essentially impossible to meet code with a staircase that isn't at least 5 ft in diameter.
You should also know that in some places, a spiral staircase cannot be the primary means of access to a space.
The Following 2 Users Say Thank You to md2lgyk For This Useful Post:
02-03-2013, 08:11 AM
#7
Super Moderator
Originally Posted by md2lgyk
T
I was wondering about that-----
How would you ever get furniture up one of those?
02-03-2013, 08:51 AM
#8
same way you build a boat in your bsmt that's too large for the door 1 board at a time
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
02-03-2013, 09:42 AM
#9
JOATMON
Use the link by Oh'Mike....we actually have one of those spiral stair cases in the garage....
Easy to install....
A few points.....
As noted above, your opening is not large enough....I got by with a 5'x5' opening (tread width 24")....since it's just a garage....it's fine....if it's a living area, the width has to be more. I think your going to need at least a 5.5 x 5.5 if not larger opening.
Don't get carried away with trying to save money on using less treads....I went with an 8" rise....max should be about 7.5".
Overall, we love the stairs.....the only downside...I wish I had gone a fraction larger.....
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
02-03-2013, 09:56 AM
#10
I guess all your furniture would have to be Ikea - you could assemble it after it's upstairs.
In our log house, the stairs go to the loft area. The entire loft is open to the floor below (with railings, of course). We muscled most of the furniture up there before I installed the railings. The biggest PITA was the Tempurpedic mattress.
Our staircase looks just like the one in ddawg16's picture. It's even the same color.
I can understand why spirals are not legal for primary access in some locations. The take some getting used to, and are tough to negotiate in a hurry.
The Following User Says Thank You to md2lgyk For This Useful Post:
02-03-2013, 11:12 AM
#11
STAFF
You should install an "I" hook in the ridge board right at the edge of your loft. Then make a pully system with a hook that would hook in the I bolt, when you aren't using it you could store it. If you really want to get creative buy one of the small electric hoists and hang it there when needed.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
02-03-2013, 11:23 AM
#12
JOATMON
It's actually pretty easy to get stuff up....long items....you just stick it up the opening....other items....I can stand about 2 steps up and just push them onto the landing....
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
