Installing Soap Dish On Tub Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-06-2008, 08:58 PM   #1
Installing soap dish on tub wall?
Hi everyone,
I finished installing my ceramic tile on my tub. I need to install a decorative soap dish that weights I would say around 2lbs. Its made of some sort of stone, I cut the tile and left the correct space for the soap dish. What's the Best adhesive to mount this? Do I use mortar? Do I use silicone? Do I use construction adhesive. The back of the wall is cementboard. Thanks, would like a strong adhesive, don't want this falling on someones toes, lol. Thanks
helpless handyman is offline   Reply With Quote
Old 05-06-2008, 09:43 PM   #2
Registered User
Termite's Avatar
Good old fashioned thinset.
Use duct tape to hold it in place while it sets up.
Old 05-06-2008, 09:55 PM   #3
Thanks thekctermite, your always there for the rescue! Should I use the powder one, the same one used for the tile setting. I have a bag with some, buts its about 6 months old, will it be okay? Also should I spray wet the cement board as well as the soap dish on the back before applying the thinset? Also do I use the trowel, or do I just smack a ton of it, lol.
Thanks for the quick reply
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
