-   -   Installing a register directly to a vent (http://www.diychatroom.com/f19/installing-register-directly-vent-93048/)
Van3 01-21-2011 04:47 PM
Hi,
I just got my basement finished, but find that it is freezing cold. My basement is about 1200 sq.ft. and I have 3 vents and 1 return (All in the ceiling). Only one of these vents is in the entertainment area, and it is very cold there all the time. The supply from the furnace runs along the length of my entertainment area (in the ceiling). I was wondering if I could cut a 3 x 10 hole in my drywall in the ceiling, which would give me direct access to the supply and then cut a 3 x 10 hole in the metal and just cover it with a register as an easy way of creating a new vent. Please help!
Ron6519 01-21-2011 06:11 PM
I have to ask. You got the basement finished, but you made no provision for heat?
Why is that?
Ron
Van3 01-23-2011 05:47 PM
The contractor told us that we did not need any extra vents as the existing ones were enough to heat the basement.
Ron6519 01-23-2011 06:06 PM
Does the furnace have the capacity to supply heat to the basement? If it does, you should be able to cut supply ducts to the basement. If after you cut them and the house cools off, seal them back up and find an alternate heat source.
Ron
gregzoll 01-23-2011 06:23 PM
Would be best is either use baseboards. Is the basement properly insulated as the info on buildingscience.com states. If it is, you should not be cold. Do you have a thermometer to measure the temps in all areas of the basement, along with humidity levels?
Wildie 01-23-2011 07:57 PM
The cold air return should be at floor level and be approximately equal in size to the total cross-sectional area of all the supply lines.
Adding an additional warm air supply will do little to improve the situation unless the displaced cold air has some place to go.
Van3 01-24-2011 04:33 PM
Thanks for all your responses.
How would I know the capacity of my furnace (I'm a novice). The furnace is about 17 years old (Lennox). My house is about 2600 sq.ft. and the basement is about 1200 sq. ft.
Van3 01-24-2011 04:35 PM
I have 1 cold air return in my basement and it is on the ceiling.
Wildie 01-24-2011 07:28 PM
There you go and now you know what your problem is.
Hire a tin whacker and have him put in a return at the floor level.
Van3 01-25-2011 09:26 AM
Thanks, will definitely look into that!
