Installing A Pool In A Hillside - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-01-2012, 04:43 PM   #1
Installing a pool in a hillside
Hello,
I am in the process of installing a 30ft above ground pool. The topography of our yard is very hilly. We excavated a site which required us to cut into a hill and now we need to retain it. I am trying to figure out the most cost effective way to retain the hill since where it will be retained will be covered by a deck we are going to install around the pool.
The wall will be 65 ft and at its highest point will be 3.5 ft. It tapers from the middle at 3.5ft down to 1ft on the end of each side and is a half oval shape that sits back 2.5-3 ft from where the pool is going to sit.
We are looking for the cheapest way. Even considering railroad ties or using rock from our yard which is piled up from various projects. Any insight here would be great
Here are some pictures:
Thanks! John
jbravo8212 is offline   Reply With Quote
Old 12-01-2012, 04:47 PM   #2
Civil Engineer
Rewards Points: 4,572
Try those photos again, I could not see them.
Old 12-01-2012, 04:53 PM   #3
I re-sized them. The originals were WAY too big
Thanks!
Old 12-01-2012, 05:37 PM   #4
Rewards Points: 13,300
I'm missing the logic of trying to do it that way.
For one it's way away from the house, now your going to be dealing with all the cut grass being dragged into the house. How is a truck going to get to it to fill it with water, if the plan is to just use a garden hose plan on at least a week with it running 24/7. To maintain the water level your going to have to be running a hose across the yard.
All the rain run off in the yards going to be heading right where you do not want it.
I'm guessing it would have been better to have built a retaining wall, back filled and set the pool on top of the level area.
Think about it, railroad ties are ties that were removed because they had reached there expected life span.
Old 12-01-2012, 05:47 PM   #5
Hello - unfortunately this was the only place we could put it because of the septic tank which sits exactly 10ft from the top lip of where we dug out the hill. Believe me we didn't want it that far from the house.
Really what I am after is the most economical way to retain the wall. We are already over budget and I was looking for recommendations maybe on material. We have a large pile of rocks (large rocks). I was thinking about laying them on the hill and driving re-bar stakes at their bottom to keep them in place. Would this work to hold the hill back or am I crazy?
The entire wall will be covered by a deck that will be flush with the yard coming down so it wont matter how it was retained.
Also I already have began excavating a trench around the pool area to carry all the water away from the base of the pool. NOT FUN!
Thanks - John
Old 12-02-2012, 09:37 PM   #6
Rewards Points: 150
You will want to ask your Building Dept. if they require a permit for the retaining wall and if so, at what height do they require it to be engineered. Landscape ties that are treated and rated for ground contact are economical and when installed properly should be able to retain 42" of earth. You might want to consult with a local landscape architect about the stone walls. When the ground is saturated there is a lot of hydrostatic pressure. A landscape architect or engineer will be familiar with your local soil conditions.
TheCamper is offline   Reply With Quote
Old 12-03-2012, 09:12 AM   #7
Rewards Points: 528
Instead of rebar, I would use 1" black pipe and drive it in min. 18", just around the pool, maybe every 2-3'. Rust around the pipe tends to keep it locked to the earth. Still just around the pool where slope faces the pool wall, start building a wall with synthetic decking, bending it along the radius. Synthetic would give you best ground contact protection, then build up with synthetic or PT up to about 2/3 of the height of the grass. Fill the void with your rocks, gravel. I think you dug out more than necessary, so rest of the area can be regraded and retaining not necessary.
We are talking about above ground pool. I would just make sure the foundation ground is well tamped.
Inspector's primary concern would be there is a fence around the pool from the deck and security door closes by itself. The usual height of the pool is high enough where there is no way to climb over the pool wall.
You could remove that tree shadowing the area just in case and also one less tree that'll dump the leaves into the pool.
carpdad is offline   Reply With Quote
Old 12-04-2012, 02:43 PM   #8
That's a great idea!!!! I did have a question though. Since ill be driving the stakes in the ground I'm assuming that I will secure the scenthetic deck boards to those stakes which will be curved to wrap around the front of the pool just where it faces the wall right?
Old 12-04-2012, 11:47 PM   #9
Rewards Points: 528
Yes. Idea is to stop the erosion towards the house and to keep the mud collecting around the pool.
Is being shocked in a properly bonded pool truly impossible or just improbable? LeighB Electrical 36 05-30-2013 01:08 AM
Sand Fill For Swimming Pool Thumbhammer Concrete, Stone & Masonry 20 11-01-2012 11:06 AM
Installing Pool System New v. Used? flowerchick General DIY Discussions 5 10-27-2011 08:28 AM
Bonding Pool Equipment - Conflicting Advice rickster18 Electrical 6 08-18-2011 06:21 PM
Movement of cement pool deck around inground pool sgagnier Landscaping & Lawn Care 1 07-05-2010 01:31 PM
