Installing Plywood Over OSB - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 07:35 PM   #1
msaeger's Avatar
Rewards Points: 260
Installing plywood over OSB
I have 3/4" OSB down now that is running with the long edge perpendicular to the floor joists. I am going to put down 3/4" T&G plywood over it.
Do you guys think I should put the plywood down perpendicular to the OSB or the same direction to the OSB and just make sure the joints don't line up ?
Georgia pacific says to put the plywood down with the long edge perpendicular to the joists but that is when there is only one layer they don't say what to do when there are two layers.
I have read when there are two layers to have them perpendicular so what do you guys think ?
msaeger is offline   Reply With Quote
Old 03-01-2011, 09:47 PM   #2
Registered User
Rewards Points: 4,910
If going for strength, yes; http://www.apawood.org/pablog/index....-Floor-Systems
Gary
Old 03-01-2011, 10:03 PM   #3
msaeger's Avatar
Rewards Points: 260
So I should put it down long edge perpendicular to the joists then right ?
Old 03-01-2011, 10:17 PM   #4
Thats correct
mrgins is offline   Reply With Quote
Old 03-01-2011, 10:20 PM   #5
msaeger's Avatar
Rewards Points: 260
Thanks !
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Installing tile on Plywood Jefftiles Flooring 2 04-27-2010 11:02 AM
How to install 5/8" Plywood over OSB Sub-Floor ? sirjeff Flooring 9 01-21-2010 05:08 PM
Thickness of cement board on plywood ceiling hacksepe Building & Construction 5 09-13-2009 08:07 PM
Installing Ceramic tile: Ditra over Vinyl or rip out and use 5/8 Plywood? ppieda Flooring 2 10-05-2007 12:01 PM
