-   -   Installing plywood over OSB (http://www.diychatroom.com/f19/installing-plywood-over-osb-96962/)
msaeger 03-01-2011 07:35 PM
I have 3/4" OSB down now that is running with the long edge perpendicular to the floor joists. I am going to put down 3/4" T&G plywood over it.
Do you guys think I should put the plywood down perpendicular to the OSB or the same direction to the OSB and just make sure the joints don't line up ?
Georgia pacific says to put the plywood down with the long edge perpendicular to the joists but that is when there is only one layer they don't say what to do when there are two layers.
I have read when there are two layers to have them perpendicular so what do you guys think ?
Gary in WA 03-01-2011 09:47 PM
If going for strength, yes; http://www.apawood.org/pablog/index....-Floor-Systems
Gary
msaeger 03-01-2011 10:03 PM
So I should put it down long edge perpendicular to the joists then right ?
mrgins 03-01-2011 10:17 PM
Thats correct
msaeger 03-01-2011 10:20 PM
Thanks !
