Installing A New Windows In Cinder Block Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-13-2009, 07:32 AM   #1
Rewards Points: 37
Installing a new windows in cinder block foundation
I would like to replace the windows in my basement. They are pretty big for a basement window measuring at 3’ x 2’. As best I can tell the framing is completely shot and I would like to replace everything. This is (or will be) a living space in the basement
I read this post here and have a couple questions Replacing a window in a foundation wall?
I do have a Ramset with the proper zinc coated nails for PT. Can I use a the Ramset for the frame directly into the cinder block or do I risk cracking the block? Right now I can’t remember the color but I have the 2nd ‘strongest’ loads for the ram set. Would I be better off screwing the PT to the block?
If it screwed is a pilot hole drilled first?
I plan on using PT for the framing but the top and bottom with be tight with the new framing…I have plenty of room side to side. I might have to use PT that’s like ¾” think (possibly decking) Is this OK or should I have the windows custom made and use 1 inch thick framing?
I see a couple references to sealing…what is use to seal the PT after it’s framed?
One more semi related question (so I don’t have to start a new thread)..I’ll be dry locking the walls and insulating with 1’ R-5 foam. I plan on ‘gluing’ the foams to the walls. Is there a problem using standard ‘foam glue’ to the painted dry locked wall?
As always..
Thanks!!
monsterbash is offline   Reply With Quote
Old 04-13-2009, 08:48 AM   #2
if there's a water issue, drylock won't solve anything & may hide any damage that's continuing
yesitsconcrete is offline   Reply With Quote
Venting dryer through cinder block foundation wall jayp Building & Construction 10 04-08-2009 07:18 AM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 10:48 PM
Leak in the cinder block foundation. 68MHJCs Building & Construction 7 01-25-2008 10:37 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
