Installing New Attic Insulation In Old House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 11:20 AM   #1
Question
Installing new attic insulation in old house
Hi guys, I'm looking to put new insulation in the attic of our older home. What's in there now literally looks like dirt (see pics) and there's hardly any of it down. I plan on just buying the rolls of insulation because the attic is pretty small. Here are my questions:
1. Do I put the new stuff right over this old stuff?
2. Paper side down?
3. What can I do or buy to protect the can lights from the new insulation?
4. Is there anything else I should know before starting this project?
Thanks a ton guys!! See the pics of the attic below
Upnya is offline   Reply With Quote
Old 11-02-2010, 12:23 PM   #2
My home is like this. I would suggest renting one of the vacuums that sucks it out from Home Depot/Menards. Get the old stuff out.
The lights should be safe to just roll the new stuff over. If the old stuff is there and isn't catching fire, I don't think you should have a problem, but check the code on the light to make sure it is safe.
Finally, don't buy the paper backed stuff. Either put down plastic before or there should already be plastic in place. Just roll out the non-backed stuff.
I personally removed the old stuff, had plastic in place and blew in insulation from Menards. VERY EASY and much easier than rolling the stuff I did.
Highly recommend it as you can have on person outside stuffing the insulation into the machine and you can be upstairs with the controls and hose.
Good luck!
Nickum7 is offline   Reply With Quote
Old 11-02-2010, 01:16 PM   #3
In order to cover the can lights they must be IC rated
I do not think those cans are
You can either replace them with IC rated
Or keep the insulation 3" away
I would not touch the old stuff....just my preference
It will be a mess to remove/move it
I think I'd just put non-faced insulation on top
Old 11-02-2010, 04:21 PM   #4
Chicago, IL
Michael Thomas's Avatar
Is there any sort of vapor barrier currently installed under the insulation?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-02-2010, 10:40 PM   #5
Registered User
Rewards Points: 4,916
You really need to air seal the attic first, click on the download-pdf file in top right-hand corner for around the older lights and the bath fan box. Adding fiberglass before air sealing is pointless, as it's much easier to move a little insulation now to gain access to sealing areas listed: http://www.buildingscience.com/docum...ealing%20guide
They show pictures of light boxes and fan insulation, none with air permeable f.g. It appears you don't have a vapor barrier, what is your location?
Gary
Gary in WA is online now   Reply With Quote
The Following User Says Thank You to Gary in WA For This Useful Post:
whataboutj (11-10-2010)
Old 11-02-2010, 10:53 PM   #6
Does that bath fan exhaust to the outside ?
I can't tell if there is an exhaust hose on there
It should not be venting to the attic
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Gary in WA (11-03-2010)
Old 11-03-2010, 12:04 AM   #7
Put the new insulation over the old. Blowing it in will save you time and money and you will get a better install with less air gaps. You do not need a paper faced roll. Unfaced or blown-in is all you need. Add a bow in radiant barrier for superior heating and cooling performance.
www.smarthomesllc.net
danielbyrne is offline   Reply With Quote
Old 11-03-2010, 07:33 AM   #8
Chicago, IL
Before adding any type of "radiant barrier", take a look here:
http://www.greenbuildingadvisor.com/...search-problem
Old 11-03-2010, 08:08 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
FYI, the stuff you are calling dirt is cellulose fiber insulation. One of the better insulating products out there. I agree, the lights don't look like they are rated for insulation contact. If you add more insulation, you also need to install baffles at the soffit area to prevent insulation from piling up against the bottom of the roof deck and getting out into the soffit where it can block air circulation.
Old 11-03-2010, 08:43 AM   #10
Rewards Points: 6,652
What is with all of the wire snakes going everywhere?
Old 11-03-2010, 09:00 AM   #11
Enough is Enough
H. A. S.'s Avatar
Agree with Maintenance6, just add more cellulose.
H. A. S. is offline   Reply With Quote
Old 11-03-2010, 09:33 AM   #12
Chicago, IL
Appears not:
Why that's a bad idea:
Old 11-04-2010, 01:23 AM   #13
Rewards Points: 956
oh man i need to start my own attic thread!
federer is offline   Reply With Quote
Old 11-04-2010, 08:14 AM   #14
Going back and looking at the pictures, it also appears that the exhaust from the dryer vents into the attic. That is not normal dust up there covering the cellulose.
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 11:19 PM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Idea for attic insulation baffles. What are your thoughts? Ininkus Building & Construction 8 02-26-2009 01:46 PM
Attic Insulation - Do's and Don'ts reikiray HVAC 1 07-27-2007 11:21 AM
Is adding insulation in attic cost effective? AllGoNoShow Building & Construction 1 12-05-2006 12:31 PM
