Installing Mammoth Basketball Goal - Size Of Hole? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 08:51 PM   #1
Installing Mammoth Basketball Goal - Size of Hole?
Hi,
I have a Mammouth Basketball Goal that I am installing next to my driveway. There was an older concrete pad/post that had been cut off years ago in this same location. I have removed the old pad/post, but while in the process have a left over hole about 24" wide x 36" long x 36" deep. My new hole for the goal needs to be 21" x 21" x 48" deep. Should I just dig the existing hole 12" deeper and fill in the complete hole with concrete? Or is there some way I could form the larger hole down to say 24" x 24" at bottom tappered up to about 21" x21" at the top? And then fill in around the concrete block with dirt? I don't want to over-use too much concrete, but I also want to make sure the surface on each side of the concrete is solid enough to hold the concrete in place.
Thanks for the advice.
keady27 is offline   Reply With Quote
Old 03-29-2011, 09:07 PM   #2
Concrete & Masonry
Rewards Points: 526
I would suggest simply using a 27"+ sono-tube which will prevent frost from picking at the post (if applicable) and to save on total concrete.
jomama45 is online now   Reply With Quote
What size pilot hole for 3" deck screw? Goldglv General DIY Discussions 16 01-17-2010 09:45 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Using sharkbite to fit leak in pipe...pipe hole size question. RyanD Plumbing 4 08-14-2009 07:17 PM
Door knob hole size discrepancy janralix Carpentry 8 08-04-2009 09:11 PM
