Old 02-22-2009, 12:13 AM   #1
Installing insulation in basement ceiling
I know this question has probably been asked 1000 times but for some reason I can't find the answer...
I am putting insulation in my joists in the basement ceiling (primarily just for sound dampening). All the lighting that I bought is rated for insulation contact so I am not worried about that. What about the heating ducts? Can I put insulation in contact with those? Any other factors that I should be aware of before I start installing this?
epeterson777 is offline   Reply With Quote
Old 02-22-2009, 06:01 AM   #2
Whatamess
The heat ducts pose no problems. Are you using faced or un faced?
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 02-22-2009, 11:37 AM   #3
It is faced on one side, with some sort of clear layer on the other just to hold it together (for easily handling the package says).
I was going to lay the paper side down, but in the joists with the ductwork should I put it face up so the paper isn't in contact with the ducts?
Insulating unfinshed basement ceiling for sound daveyd Building & Construction 38 02-02-2009 11:57 AM
basement insulation CooperChloe Building & Construction 2 01-25-2009 11:12 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 10:39 AM
Basement "Edge" insulation Wil Building & Construction 3 04-05-2007 11:04 PM
Vaulted Ceiling Insulation Problem casey_wa Roofing/Siding 13 05-08-2006 10:55 AM
