Installing A Home Depot Prehung Interior Door. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 12:19 PM   #1
Installing a Home Depot prehung interior door.
We have a rough opening just under 34 inches and a 32 inch prehung door. The hinge side jamb is level. The door is loosely in place with screw fasteners installed hidden beneath the hinges. I'm trying to get the hinge side of the door to properly align without door closure binding using shims. It's not working out well. Any tips?
John58 is offline   Reply With Quote
Old 10-31-2010, 01:17 PM   #2
the Musigician
DangerMouse's Avatar
So... it's pinching? Top or bottom?
Can you post pictures? They always help here.
DM
Old 10-31-2010, 01:31 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
If you look at the hinge half that is fastened to the door it will have two or three flanges on it. If your door is dragging on the top of the door bend the hinge flanges on the bottom of the door in towards the door. Don't bend them much or you will hinge bind the door. If the door is dragging on the bottom edge, bend the top hinge flange inward. What it does when you bend a hinge is it will move the door closer to the hinge side and away from the striker side. Also note that by bending the hinge it will raise or lower the door on the knob side so if the door doesn't close because the door raised or was lowered and the striker won't catch you will have to adjust he striker.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-31-2010, 01:59 PM   #4
Thank you
Thanks for the help!
The Following User Says Thank You to John58 For This Useful Post:
BigJim (10-31-2010)
Old 10-31-2010, 08:20 PM   #5
Rewards Points: 5,336
This reminds of my first prehung door. I also had the jambs level. Luckily for me the house was inhabited by drunks who rolled through the opening like cord wood.
Thanks for the memories.
Ron
Home Depot? (x-post) Humble Abode Tools 28 02-12-2012 05:06 PM
Home depot 44 dollar interior pre-hungs any size.... Alan General DIY Discussions 12 02-14-2010 12:22 PM
Home depot or lowes toeey1 General DIY Discussions 10 02-12-2010 02:18 PM
It took the Home Depot three roofs to get it correct! anewroof Roofing/Siding 10 11-27-2006 07:55 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
