Old 05-20-2010, 12:51 PM   #1
Installing Hardiplank in Texas
I currently have "masonite" siding that is rotted in many places. I repaired over the years but want to replace with HardiPlank.
My question: The masonite siding was installed directly onto the 2x4's without any barrier or insulation material. I've seen the benefit of adding felt/siding paper, etc. and agree that should be done. However, becasue it hadn't been done originally, was there a reason or just taking the cheap way out.
Also, is there additional benefit for installing foam board also for additional insulation? Again, same question regarding it not being done originally.
Will installing the foam board cause me problems with the additional 1/2 inch of material? I can't see that it would, but....?
Thank you very much!
scott91651 is offline   Reply With Quote
Old 05-20-2010, 11:34 PM   #2
rock16's Avatar
I think the reason is somebody was just saving money.
There is a benefit to using rigid insulation and you may qualify for the tax credit if you do. Hardie has a tech bulletin out on the subject.
If you install the foam you should plan ahead on how you are going to trim the windows, this is the biggest problem spot when you make the wall thicker.
God luck
rock16 is offline   Reply With Quote
The Following User Says Thank You to rock16 For This Useful Post:
Tom Struble (05-20-2010)
Installing Vinyl Siding ptarmigan61 Building & Construction 9 02-24-2010 09:22 PM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 10:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 12:11 PM
Installing Hardwood questions myphaykename Flooring 10 01-23-2009 09:48 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
