-   -   Installing Hardiplank in Texas (http://www.diychatroom.com/f19/installing-hardiplank-texas-71685/)
scott91651 05-20-2010 11:51 AM
I currently have "masonite" siding that is rotted in many places. I repaired over the years but want to replace with HardiPlank.
My question: The masonite siding was installed directly onto the 2x4's without any barrier or insulation material. I've seen the benefit of adding felt/siding paper, etc. and agree that should be done. However, becasue it hadn't been done originally, was there a reason or just taking the cheap way out.
Also, is there additional benefit for installing foam board also for additional insulation? Again, same question regarding it not being done originally.
Will installing the foam board cause me problems with the additional 1/2 inch of material? I can't see that it would, but....?
Thank you very much!
rock16 05-20-2010 10:34 PM
I think the reason is somebody was just saving money.
There is a benefit to using rigid insulation and you may qualify for the tax credit if you do. Hardie has a tech bulletin out on the subject.
If you install the foam you should plan ahead on how you are going to trim the windows, this is the biggest problem spot when you make the wall thicker.
God luck
