Installing Flue Liner Thru Damper - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-16-2009, 11:39 PM   #1
Installing Flue Liner thru Damper
Hi all,
I'm thinking about installing either a gas insert or a wood burning stove in an existing fireplace, but I'm unsure about how to install a new flue liner through the existing damper. The damper is wide, but not very deep - probably 4-5 inches deep by about 20" wide. The opening for the damper is probably slight less than this.
I belive the liner I would need for a wood burning stove would be about 6" and will not fit through the damper.
How much trouble is it to remove an entire damper and plate so a 6 or 7 inch flue liner can be fitted? I can't be the only one with this problem.
MikeinBurien
MikeinBurien is offline   Reply With Quote
chimney liner schu General DIY Discussions 7 11-19-2008 09:05 AM
Fireplace damper Potomac101 General DIY Discussions 4 01-26-2008 04:21 AM
New Flue Liner Regulations-NY Ron6519 HVAC 5 11-27-2007 10:28 AM
Advice Needed re: Chimney Liner for Oil Furnace Mike_R HVAC 3 11-27-2006 03:04 PM
