Installing Floor In Family Room With High Ceiling. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-08-2011, 10:38 AM   #1
Installing floor in family room with high ceiling.
We are moving into a new home. The home has a family room with a very high ceiling (18'). The upstairs hallway over looks the family room. We want to put a floor across the family room even with the floor of the upstairs hallway to create an open common area on the second floor.
I have been doing a lot of research, but would very much appreciate more professional insight. My current thought is to run the floor joists from the wall on the side of the family room supporting the upstairs hallway to the outer wall. I have not been able to measure the distance exactly, but it is between 14' and 16'. I have to remove to windows on th outer wall that would be cut in half as a result of installing the floor.
On both sides there is no sill to sit the joists upon. Both sides have band joist sitting on top of the wall structure below. Can I just use joist hangers to span across the room? I would attach the hangers to the band joist on both sides.
Thank you
jrwilkinsonjr is offline   Reply With Quote
Old 05-08-2011, 02:00 PM   #2
Rewards Points: 5,336
You will need plans and a permit for this project. I suggest you talk to an Architect so he can come up with a suitable scenario.
The Following User Says Thank You to Ron6519 For This Useful Post:
jrwilkinsonjr (05-08-2011)
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 04:47 PM
decoupled ceiling and wall install for the snoring room crankcase Drywall & Plaster 6 02-18-2011 02:15 PM
Paint a room and ceiling - Newbie painter louiemiranda Painting 6 03-20-2010 09:28 PM
Is my room pre-wired for a ceiling fan? cfrederick02 Electrical 1 04-02-2009 01:08 PM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 08:10 AM
