Installing Facia In Hip Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 01:12 PM   #1
installing facia in hip roof
installing fascia board on a 6/12 square cut hip roof. need to make compound miter. does anyone know the angles required. i know ones a 45 but cant get the other
Mike47ma is offline   Reply With Quote
Old 08-31-2011, 01:20 PM   #2
Rewards Points: 5,336
The wrap around of the fascia would be 90 degrees if the rafter tails are cut plumb. The corners should be 45 degrees.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Mike47ma (08-31-2011)
Old 08-31-2011, 05:42 PM   #3
Fascia install on hip roof
The rafters are not plumb cut,they're square cut so the corners require a compound miter on a hip roof. Dont know the angles for a 6/12 pitch hip for the fascias
Old 08-31-2011, 05:53 PM   #4
Rewards Points: 150
Don't know if this will help but when I have complicated cuts, I work it out on scrap boards first to get the pattern, then cut my good board when I am positive it is correct. In my experience, it is highly likely that none of the corners will be the same and you will have to tweak your pattern a little at every corner. Good luck!
guest is offline   Reply With Quote
Old 08-31-2011, 11:26 PM   #5
firehawkmph's Avatar
Rewards Points: 1,898
Mike,
6/12 pitch should be 26.5 degrees. Like Guest said, try some scrap pieces first.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Installing a roof in cold weather papageek Building & Construction 6 11-03-2010 10:57 AM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
installing foam board on pitched roof David63 Roofing/Siding 5 04-01-2010 11:36 PM
Installing a rubber roof! Wildie Roofing/Siding 11 01-08-2009 07:14 PM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 05:01 PM
