Installing Dryvit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-06-2010, 10:38 PM   #1
Question
installing dryvit
has enyone ever installed dryvit over existing rock veneer?
norman clifton is offline   Reply With Quote
Old 05-07-2010, 08:27 AM   #2
have you done any reseach on this produt yet?
clasact is offline   Reply With Quote
Old 05-07-2010, 12:41 PM   #3
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 808
Wow. That is a product you do not want to be taking shortcuts with. There's a house a few blocks over with Dryvit, and it's leaking like crazy.
Aggie67 is offline   Reply With Quote
Old 05-07-2010, 01:28 PM   #4
Rewards Points: 1,220
Dryvit is a brand name. They have many different products and systems, and somewhere someone has surely installed it over stone. And it probably failed.
For most of their systems, you have to be a certified installer to buy it.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 05-07-2010, 01:58 PM   #5
kwikfishron's Avatar
Rewards Points: 86
Definitely not for wet climates. I’ve torn off three houses of it so far. What a mess.
kwikfishron is offline   Reply With Quote
Old 05-07-2010, 03:53 PM   #6
Totally screwed together
Originally Posted by kwikfishron View Post
Definitely not for wet climates. Iíve torn off three houses of it so far. What a mess.
I did a bunch of research on Dryvit for my BIL in Buffalo...
On those houses you tore off, did they have the correct rain screen and drainage planes?
xxPaulCPxx is offline   Reply With Quote
Old 05-07-2010, 04:35 PM   #7
Rewards Points: 86
I have no idea, I got the jobs from a GC and was just there to get it done. All three were built by the same builder though.
We were replacing rot everywhere. All sides of windows, headers, corners, roof to walls.
All of them were only 4-5 years old
Two of them were front row on the ocean the other was about a block in.
I have no idea who did the installs or if they did it correct. I don’t know the certified way to install the stuff and from my view don‘t care to learn.
Old 05-07-2010, 05:06 PM   #8
From what I learned, the key to that system is in the drainage plane. Since it was the same builder, I'd bet they used the same details... or lack of details.
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 10:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 12:11 PM
Installing kitchen cabinets before new flooring kchopper Remodeling 5 12-29-2009 11:51 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
dryvit question/opinions thepinkhammer Building & Construction 5 01-25-2008 09:53 PM
