Installing A Drop Stairs. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2010, 05:39 AM   #1
Installing a drop stairs.
I would like to access my crawlspace above my garage. The drop down stair systems that I have looked at, require me to cut a ceiling joist out in order for it fit. Do I sister additional 2x10's next to the one joist I am cutting & put in a header piece in on top & bottom of opening? I am following the length of joist, not cutting accross it. Thanks
kskier is offline   Reply With Quote
Old 07-01-2010, 09:16 AM   #2
Yes, in some cases blocking to the next set of joists is also a good idea
Old 07-01-2010, 09:38 PM   #3
Registered User
Rewards Points: 526
With existing 2x10's as ceiling ONLY joists......... Now you are adding a storage load to deep joists that are probably at their span limit now with just the ceiling load.
1. How big is the span, in feet?
2. Distance of on center spacing, in inches?
3. Type of wood (species)?
4. Location of stairs in span?
5. Weight of stairs?
6. Storage weight?
7. Garage door back-hang supported from joists near (or on same joist) proposed stair?
Be safe, Gary
Old 07-03-2010, 09:03 AM   #4
thanks
thanks for your reply. I hadn't thought about the extra weight. I will have to explore these questions...............thanks
installing bamboo on stairs....with crazy angles norcalsurfer1977 Flooring 7 07-24-2012 07:16 PM
Need help installing hand and stairs rails jeff9353 Carpentry 13 02-08-2010 08:16 AM
Installing Hard wood in hallway with stairs basledder Flooring 1 11-03-2008 04:56 PM
Installing can lights in a drop ceiling..... rwk0930 Remodeling 1 02-19-2008 12:59 PM
Foundation Work - Installing a walk up stairs handy man88 Building & Construction 2 10-01-2007 12:19 PM
