Installing Columns - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-01-2010, 06:29 PM   #1
Rewards Points: 274
installing columns
I was wondering how much you usually have to jack up the the porch beam to slide columns in. I cut columns tight (of course) so the weight will help hold. I always worry about jacking up too much and causing damage to framing, roofing (metal), soffit/fascia, something.....
ugabulldog is offline   Reply With Quote
Old 10-01-2010, 06:55 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 582
I always jacked up no more than 1/2 inch. If the column is the right length it will go with no problem.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Replacing Porch Columns mcwolfe6 Building & Construction 8 05-12-2010 06:51 PM
Replacing porch columns MPH Building & Construction 5 04-01-2010 09:19 AM
Interior Column's larrylwill Remodeling 4 07-26-2009 02:05 PM
Installing fiberglass columns dudical-ninja Carpentry 4 08-28-2008 04:27 PM
Installing new front porch columns puma24boy General DIY Discussions 2 12-03-2007 03:27 PM
